sbc 434 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2013, 03:16 PM
sbc 434 stroker
Hi Guys! I have built some extreme enginges in the past but this is the first large displacement small block that I'm looking at doing. I have a 1976 2 bolt main chevy 400, which is being machined as I post this, to a splayed 4 bolt. Boring it out .030 but I want to take it to a 4.00 stroke. Target compression ratio is 9.0 to 9.5. Max rpm would be 5500, no more. Engine is being built for a boat, open cooling system ran in fresh water lakes. Will I need to clearance the block for the crank? Any danger of cracking the block. Anybody have personal experience doing this? Can I use a stock oil pan?
Thanks in advance for the info
Old 04-21-2013, 03:38 PM
if you still can, stop the machine work and just order an aftermarket block now.
chances are good you'll hit water because yes, you'll need to clearance the block.
and stock pan isn't going to work. check for a milodon stroker pan, they work well.
Old 04-21-2013, 03:46 PM
vinniekq2's Avatar
a 421 is possible.I would buy the dart shp block.My 434 is in a dart little "M"
Old 04-21-2013, 03:58 PM
vinniekq2's Avatar
you should not bore the engine with out pistons in hand...
you need heads to flow close to 300 cfm to rev 5500
Old 04-21-2013, 08:54 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
How much is all that machine work costing? My machine shop wanted $800.00 to bore, hone, deck and splay a junkyard 2 bolt block. I opted to buy a brand new Dart SHP for $1600.00 for my build.
Old 04-21-2013, 11:35 PM
IMO your going to pay a LOT of extra money for a few cubic inches. I cant see spending so much money for an engine that's only going to spin to 5500rpm. You may want to check out this book.
Amazon Amazon
Old 04-22-2013, 06:54 AM
New Member
Re:
S 10 Racer, donít you think itís a bit too expensive. Plaintoast, I totally agree with you.
Help building a 434 Stroker 69chevy 434ci Engine 29 06-02-2011 08:05 PM
434 Stroker in a 69 Chevelle 69chevy 434ci Engine 8 05-27-2011 08:01 AM
434 chevy stroker Hammerchvy Engine 2 01-07-2010 11:24 AM
sbc 434 stroker sb72elcamino350 Engine 11 03-17-2004 10:19 AM
sbc 434 stroker sb72elcamino350 Engine 0 03-09-2004 11:17 PM
