sbc 434 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2004, 11:31 PM
sbc 434 stroker
Hello,
What is all involved in making a sbc 434 stroker?
And what would be the best rod length for a 434 Stroker just curious?
Thanks
And is it worth it or should I just build a 406?
Old 03-10-2004, 10:35 AM
johnsongrass1's Avatar
Race it, Don't rice it!
What's the application?
They are powerful motor's but they can get expensive as well all of the machining that has to bere done. They are normal built with 400's.
Old 03-10-2004, 10:42 AM
lluciano77's Avatar
I chose to build a 404. It is a .030" 400. That way I might get another rebuild out of it in the future.
I used this kit:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33620
Notice how it has the 5.7 rods. With those, your piston pin stays below the ring lands.
Here is a 434 kit. It uses 6" rods:
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2945247888
The pins are in the lands with 6" rods.
Here is another kit to consider, a 420 ci.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2943591758
Old 03-10-2004, 03:26 PM
What kind of power could you exspect out of a 434 compard to a 406?
Thanks
Old 03-16-2004, 10:27 PM
How much torque does a sbc 434 stroker make? And what has to be done to fit that large of a crankshaft?
Thanks
Old 03-16-2004, 10:36 PM
firestone's Avatar
http://teamrfc.gospelcom.net
I am fairly sure that you have to use an aftermarket block to make a 434, something like a dart iron eagle or world products merlin. As far as the power difference, it somewhat depends on the parts. If you went with AFR heads, on pump gas you could expect 1.4 hp/cubic inch with a fairly streetable cam out of either a 406 or a 434. In that case, you would be looking at 568 in a 406 and 607 in a 434. These are just rough estimates, but it gives you something to go off of. The 434 would also make more torque, but alot of that depends on what cam is used. As far as rod length goes, I would get a hold of JE and ask them what the longest rod is that you can use without having to go to a custom piston in whatever block you use.
Good luck
Adam
Old 03-16-2004, 10:46 PM
what is the deck height of a sbc 400? I would like to find out if you need a aftermarket block or not, because if you do I do not want to do that? Does anyone know if you need a aftermarket block or not?
Thanks
Old 03-17-2004, 01:26 AM
adfishe's Avatar
New Member
You could use a 400 block. I would not advise it because you have to bore it to 4.155 with the 4.00 stroke. This leaves the cylinder wall to thin for that kind of cylinder pressure. You would have to grouted it and then have a cooling problem. Speed-o- Motive offers a street version that uses an after market block. They advertise 675 hp. The cam in this street version doesn't look very street-able to me but the large cu. inches will tone it down some. The Dart Iron Eagle block after being bored to 4.155 still has .250 of wall thickness.They also advise not using the 400 block. The deck height should be 9.025 to 9.030 if it has not been decked. The Dart block can be bought for around $1,800.00 and a good Eagle 4340 rotating assembly on E-bay for less than $1,600.00. Then to make 600 to 650 hp you are going to need a good set of heads with an intake runner in the 230+ cc range. ( Brodix 18 spx)The intake runner size will depend on what RPM range you intend to make the power . Smaller runners produces the power at lower RPM and then falls on its nose on the big end.
With this set-up in the right car you could run with most of the Big Boys with their BBC's. If you want to go fast and get there quick cu inches is the key.
Old 03-17-2004, 06:03 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
There is no problem in boring a 400 block .030 over to 4.155 Maybe 1 out of 10K may be bad from a core shift. I have built numerous 406 motors and never had one problem.
I have a 427 small block in my Vette and cruise all over the state and the Woodward cruise, if there was a cooling problem for sure I would have had one there.
This is a wives tale. Its all in how its built and whos doing it.
Any bore over .030 should have the water jackets grouted for strength and cracks and there is NO problem with cooling.
The grout is below the freeze plugs where there is barely no coolant anyways.
Try a site search on 400s on this site at the bottom of the main forum page as described in the Guidelines for posting.
This has been discussed a few dozen times already so you will find your other answers there.
Thats my .3 1/2 cents worth.
The end.
http://www.hotrodders.com/t25815.html
Luv the smell of NITRO in the morning.
Old 03-17-2004, 09:25 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Depending on the grout height, you can get into oil cooling problems so an oil cooler is a good idea. Normally when the oil is slung from the crank to the block walls, it gives up some heat to the water through the block. Granted there are other surfaces that do the same, the oil cooling capacity is somewhat reduced. This is normally only a problem on blocks that are tall filled to the water pump.
Chris
Old 03-17-2004, 09:34 AM
Just build a 406. A top notch engine builder can obtain 2HP per cube. So at that the power difference would be 56HP. And thats a $50K engine making that kind of power NA.
Chris
Old 03-17-2004, 10:19 AM
King of my Man-cave.
I agree about the 406. I have a customer who just built a 434, didn't grout the block, had me (creatively) reprofile his rods to clear his cam. About the same time, another customer of mine did a 408 (.040" over), didn't f with the rods. Both are running 6 "H-beam rods, large solid cams, external balance. Be interesting to see whos lasts longer. Meanwhile, a circle track customer of mine is building an internally balanced 406, a little less cam, 5.7" H-beam rods. My money would be on HIM>
