sbc with 671 ignition run on probs - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2006, 02:26 PM
hey guys , im finishing up a 358 with a 671 with 2 predators , i just got back from a 5 mile test drive with it , and it runs on when shuting down , it just started to do this , well this is the first time i actually let the engine run a good long time
but here are the stats
358, 671, 2 predators , it has an msd digital 6 ignition , with probillet distributer
timing is locked out at 33 degs , i used to drag race so i always liked locked out timing , could this be the problem with the run on when hot ?
yes the 2 predators are tuned properly , no black smoke and the plugs looked good after bringing it back , light brownish
[IMG][/IMG]
Old 09-03-2006, 04:58 PM
runn141's Avatar
your msd ignition box may require a diode in the , ithink its the brown wire coming from your alternater. if not that it could be to much timing, a vacuum leak will also cause runon.
Old 09-03-2006, 05:26 PM
hmmm , ill need to check out that diode, i got this box years ago and i do remember a diode when i had it in the drag car , but never paid attention to it
when i locked out the timing i had it tig welded solid becuase one day at the track the little screw msd had came off and blew up my rotor and cap, a freak accident lol , but i think im gonna try to get a new shaft and try to get the timing down to 15 or so at idle and then bring it in .... i dunno , it confuses the hell out of me becuase all timing should be in at 3000 being 32 deg or so , then use a retartard box to take it back down ,
with my setup , i got in it and by 3500 it was putting out 6lbs of boost , i was told that it should be 8lbs at 6000 so who knows
sometimes i think i should have taking up golfing as a hobby instead of custom car building ... ugh
Old 09-03-2006, 10:37 PM
ok so i read alot on the msd tech site forums , im gonna try the ballast resistor to kill this engine , seems like alot of guys with 1 wire alts and electric fan used this ballast resistor so i will try it boy i hope it works
Ignition and engine advice Jare Engine 2 03-09-2004 02:21 AM
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 06:42 AM
What do i need to run a Digital 6+ ignition? Dubz Engine 1 01-03-2004 05:56 PM
What cam do you run in your SBC? western star Engine 12 10-04-2003 07:59 PM
What ignition system should I run? Hot Rod/SS Electrical 1 01-27-2003 10:29 AM
