sbc in a 87' cutlass suspreme - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2005, 09:12 PM
New Member
it hard to put a sbc in a 87' cutlass suspreme without any problems. are there any problem i might run into if i this route the only reason i plan on putting a sbc in a cutlass is because the motor was given to me.
Old 04-25-2005, 09:36 PM
E.T. divided by $ spent= Speed
A Cutlass is a montecarlo made by Olds basically.Its a G body.
If its got a V8 Olds(307)in it now just a motor mount move and all the bracketry and pulleys and exhuast manifolds for a SBC is needed.Also emmisions stuff for A SBC,if nessesary.
If its a V6 now then you'll also need new front springs and an alignment.
Thats basically it.
Old 04-25-2005, 09:40 PM
DoubleVision's Avatar
Slam dunk, easy swap. If the car has a 6 cylinder in it, it`ll involve a little more work but not much. if it came with a 307 olds engine it`s almost straight forward. You`ll need small block chevy mounts which bolt right up, just get mounts for a 87 monte carlo with a small block. V8 cutlass has fuel lines on passenger side, makes for easy hook up, V6 has them on drivers side, so some fuel line routing will be called for. V8 has battery on drivers side, so again, some rerouting is needed. V6 is on passengers side, straight forward. if it has a V6 you`ll need a V8 cutlass crossmember, which lines up perfectly with a TH350 short tail transmission. If it has a V6 I`d recommend V8 coil springs for your own safety. Also if it came with a V6 you`ll need the V8 radiator, clutch fan, and fan shroud. You`ll have to get some exhaust work done. you`ll need to take the time to seperate the computer wires from the main wires, the computer wires will be all on the passengers side. Seperate and mark the temp and oil pressure wires off the main side so you`ll know which is which. one thing to remember, if it`s a V8 car, there`s a fuel vapor/vent line that runs to the carbon canister, that will be sitting in the battery well on the passengers side, since a small block chevy has to have the battery on the passengers side the carbon canister has to be removed, so the vapor line will have to remain open, if you cap it off, you`ll have nothing but endless fuel pressure problems, solution here is, cap it off and run a vented gas cap. one final tip, I`d run a ground from the block to the frame, just clean the frame and run a ground to the bolt that holds down the brake line on the back of the frame under the engine, then after the engines installed, run a ground from the block to the frame, this will help alot if you plan to use headers, and even if you don`t run headers, it`s still a good idea. make sure you reconnect all the factory grounds as well.
Old 05-04-2005, 04:21 AM
ChrisMiddleron's Avatar
Hey I have a 1986 Olds Cutlass with a 307. Will the transmissions that came with the 307's from factory bolt up and work with a sb 350?
I would really appreciate it for that info.
Thanks,
Chris
Old 05-04-2005, 05:12 AM
poncho62's Avatar
Wiki Edits: 5
Some of the Old/Pontiac/Buick trannys have a dual pattern that will fit Chevys too..............you will have to check. If not, a Chevy tranny will bolt right in with the Chevy motor. Other than the bolt pattern, they are the same.
Old 05-04-2005, 11:31 AM
USAF F-16 ELECTRICIAN
there is also an adapter plate that you can buy from most places e.g. JEGS for about 45 dollars. that should be fine unless you are building up a powerhouse.
Old 05-04-2005, 12:10 PM
Nah just a swap for a little extra horsepower. Thanks everyone
Old 05-04-2005, 11:02 PM
280zxWith305's Avatar
<--- Gas Bootlegger
lol off topic but i bought a 91 cutlass calais from a crackhead for 300 bucks.. just needs a new power steering hose... some people go figure lol and it dont even have the v-6.. its gotta "4-tec" hah
Old 05-04-2005, 11:07 PM
Siggy_Freud's Avatar
. . . so was it really worth the 3 bills or did you get owned by a crackhead?
Bringing history and technology together.
Old 05-05-2005, 06:20 AM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
lol @ siggy, hey I'm sure the car has been well maintained. You know how crackheads are all about keeping the oil changed.
Old 05-09-2005, 10:25 PM
<--- Gas Bootlegger
well considering i bought it to resell... i gotta good deal.. get a grand out of it.. make 700 bucks profit.. thats how i make my extra money.. buy cars cheap an fix/resell them..
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
87 350 sbc core rally4x4racer Engine 15 09-09-2006 04:56 PM
ZZ3/4 cam into pre 87 SBC? RX7Jeff Engine 2 03-06-2005 07:07 PM
Pre/post '87 SBC differences? Gearhead forever Engine 2 02-22-2005 08:17 AM
87 SBC 350 Internal / External balanced?? punk1c5040 Engine 11 03-24-2004 07:12 AM
