-   -   sbc with acessory hole on short waterpump (http://www.hotrodders.com/forum/sbc-acessory-hole-short-waterpump-224687.html)
cablebean 10-05-2012 11:59 AM
acessory holes on short sbc watepump
vinniekq2 10-05-2012 01:13 PM
welcome to the forum.Maybe introduce yourself and post a question. There are many great people on this site that are willing to help and eager to meet you.
cablebean 10-10-2012 11:08 AM
raced at lions in 60's. attended last drag race in 71
need short sbc water pump with acessory holes for alternator thank you ,cablebean
cdminter59 10-10-2012 11:42 AM
What year, make, and model is the car or truck you are working on? Most early model chevys with the short water pump had year specific power steering brackets and alternator brackets that bolted to the water pump and first two holes of the exhaust manifold on drivers side. The heads didn't come with holes drilled for accessories. Advance Auto Parts carries the short water pump remanufactured by cardone.
toddalin 10-11-2012 10:52 AM
The Header Power Bracket was designed just for your application. They have both left and right sides and mount using either the #1/#2 or #1/#3 bolts. They also have billet aluminum spacers available in different styles and finishes.
http://www.largescaleonline.com/eima...racket_105.jpg
http://www.largescaleonline.com/eima...racket_119.jpg
HEADER POWER BRACKET****** - Home
cablebean 10-11-2012 01:37 PM
accesor holes on short waterpump for sbc
have a 73 nova with the acessory bolt holt in the head. have a short altrnator and a cnc alternator support bracket that bolts to the waterpump. it is a very nice looking setup. would like to get a polished alumunum short water pump to use cnc bracketa(polished aluminum)and custom alternator(polished aluminum also). thank you
cdminter59 10-11-2012 02:18 PM
sbc with accessory hole on short water pump
Check this website for a polished aluminum water pump to fit a 1973 Nova 350. Weiand 9240P - Weiand Action Plus Mechanical Water Pumps - Overview - SummitRacing.com
poncho62 10-11-2012 02:32 PM
73 Chevy with alternator on the passenger side would use the long water pump....Trying to mix and match long and short parts is trouble getting things to line up
cablebean 10-14-2012 11:33 PM
thank you, i am trying to put a blower on need extra room jn engine .
cdminter59 10-15-2012 04:23 AM
Check this website see if this is what you want. Holley Performance Products Action +Plus Water Pump*9208P
