sbc with acessory hole on short waterpump - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2012, 11:59 AM
acessory holes on short sbc watepump
Old 10-05-2012, 01:13 PM
vinniekq2's Avatar
welcome to the forum.Maybe introduce yourself and post a question. There are many great people on this site that are willing to help and eager to meet you.
Old 10-10-2012, 11:08 AM
raced at lions in 60's. attended last drag race in 71
need short sbc water pump with acessory holes for alternator thank you ,cablebean
Old 10-10-2012, 11:42 AM
What year, make, and model is the car or truck you are working on? Most early model chevys with the short water pump had year specific power steering brackets and alternator brackets that bolted to the water pump and first two holes of the exhaust manifold on drivers side. The heads didn't come with holes drilled for accessories. Advance Auto Parts carries the short water pump remanufactured by cardone.
Old 10-11-2012, 10:52 AM
The Header Power Bracket was designed just for your application. They have both left and right sides and mount using either the #1/#2 or #1/#3 bolts. They also have billet aluminum spacers available in different styles and finishes.
HEADER POWER BRACKET****** - Home
Old 10-11-2012, 01:37 PM
accesor holes on short waterpump for sbc
have a 73 nova with the acessory bolt holt in the head. have a short altrnator and a cnc alternator support bracket that bolts to the waterpump. it is a very nice looking setup. would like to get a polished alumunum short water pump to use cnc bracketa(polished aluminum)and custom alternator(polished aluminum also). thank you
Old 10-11-2012, 02:18 PM
sbc with accessory hole on short water pump
Check this website for a polished aluminum water pump to fit a 1973 Nova 350. Weiand 9240P - Weiand Action Plus Mechanical Water Pumps - Overview - SummitRacing.com
Old 10-11-2012, 02:32 PM
poncho62's Avatar
Wiki Edits: 5
73 Chevy with alternator on the passenger side would use the long water pump....Trying to mix and match long and short parts is trouble getting things to line up
Old 10-14-2012, 11:33 PM
thank you, i am trying to put a blower on need extra room jn engine .
Old 10-15-2012, 04:23 AM
Check this website see if this is what you want. Holley Performance Products Action +Plus Water Pump*9208P
Difference between long and short waterpump bigtread Engine 4 10-23-2011 06:25 PM
chevy short snout waterpump Smokeytires Engine 1 04-10-2010 07:27 PM
Will a short waterpump work on a TPI350 upstand2 Engine 3 02-06-2010 07:12 AM
Short Waterpump on a GEN 6 BBC 454headache Engine 3 10-29-2009 08:00 PM
5" waterpump bolt (Ford 289) head broke off and frozen in waterpump ccarccrazy Engine 6 07-14-2006 02:31 PM
