Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC adjusting roller rockers.
Old 09-28-2009, 09:27 AM
pittbull7934 pittbull7934 is offline
Originally Posted by S10 Racer
While using solid lifters with a hydraulic cam has and is being done, it's not recommended but since you have solid lifters, you will always have a "ticking" sound because you have to adjust these with a lash setting. Because of the mismatch, I would set the lash at .022 on both intake & exhaust. The only way to get it quite is to change to hydraulic lifters and then you can adjust them to "0" lash.
When you say solid lifters, do you mean they are not roller lifters? Or can hydrolic lifters also not have rollers.
When you asked whether they were solid or hydrolic I thought ou were asking whether they were roller lifters.
If I have the right lifters with my cam how would i adjust them?
I can contact the builder to make sure, but I am pretty sure he matched the cam and lifters up properly.
