Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC adjusting roller rockers.
Old 09-29-2009, 11:35 PM
jimfulco jimfulco is offline
Originally Posted by S10 Racer
You can look at the top of the lifters and if you see two small wires running across the top (one wire on each side of the pushrod), it's a pretty sure bet you have solid lifters.
Pretty much every stock-type hydraulic lifter I've ever seen has had that kind of straight-sided wire clip at the top.
