Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC adjusting roller rockers.
  #23 (permalink)
Old 10-01-2009, 11:33 AM
pittbull7934 pittbull7934 is offline
Originally Posted by oldbogie
Maybe, once an engine has been fired the lifter is full of oil, it might or not move the plunger with human generated force, it's used to reacting to a valve spring of at least a hundred pounds pushing on it as the cam is moving it up or down. So if it moves when you push against it, then it is a hydraulic. If it doesn't move, then the question is still on the table.
Thanks good to know
