SBC adjusting roller rockers. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-30-2009, 01:00 AM
Originally Posted by jimfulco
Pretty much every stock-type hydraulic lifter I've ever seen has had that kind of straight-sided wire clip at the top.
My motor is def not stock, i think has the wire clips but i am not sure
i am going to post some pics from when I had the motor apart, maybe you guys can tell me what I have?
  #17 (permalink)
Old 09-30-2009, 02:06 PM
http://img2.imageshack.us/img2/1079/lifterpics.jpg
this is a pic of my motor with the heads off of it, if you zoom in you can see the top of one of the lifters, it looks to me as though it is wire that crosses the top of the lifter.
heres a zoomed pic but its not the best quality
  #18 (permalink)
Old 09-30-2009, 03:41 PM
S10 Racer's Avatar
http://www.warsprints.com
Well, I have found that there are no visual difference in the lifter as I have both with a snap ring & the wire.
Try this. If you have hydraulic lifters, you should be able to push the top of the lifter down a little. If you have solid lifters, it will not move. Give that a shot and tell us what you find.
  #19 (permalink)
Old 09-30-2009, 06:41 PM
I have 1.6 full roller rockers in my 383, can I adjust them Like I would normally adjust standard rocker arms?
I ask because I did, then I heard a ticking from the rockers, either this is normal or they are not adjusted correctly.
Thanks
Dustin
Wow this got long!
OK Dustin some basics:
1) Typical cam in block engines use a gadget called a lifter or tappet, one in the same thing. They can also be referred to as "cam followers" but this is more a Euro term and probably better fits some types of overhead cams where a follower is sandwiched between the cam and valve stem.
2) Lifter's/tappets/cam followers in definition are broken down into flat or roller. This defines what method is used to track on the cam lobe. Flat simply means the lifter is running a simple flat surface against the cam lobe. Roller means there is a wheel arrangement that is tracking along the cam lobe. Cams for flat lifter or roller lifters even if they have the same timing and lift at the valve have very different lobe shapes. Flat tappet cams come almost to a peak because in part some of their duration at the valve is in the time it takes for the lobe's peak to sweep across the width of the lifter's bottom. An identical roller liftered cam will have a wide peak because the roller of the lifter makes an instant contact, therefore, there is no sweep distance of the flat tappet so that amount of time has to be built into the lobe.
3) Because the valves expand more than the rest of the engine as they get a lot hotter, the valve train needs to accommodate this dimensional change with a distance called lash. This causes lifter's/tappets/cam followers to be further divided by how they deal with lash. This results in "solid" or hydraulic definitions. Solid lifters need a dimension of lash, or looseness, which the valve stem takes some away as it expands but never all of the lash distance as if the valve were to hang open it will burn away. Hydraulics are set up at zero lash dimension and accept the changes in the valve stem length with an oil filled plunger. Solid and hydraulic mechanisms can be applied to either flat or roller tappets.
A) Solid lifters aren't really solid pieces of metal, that would be really heavy so they are hollow inside. They have a cap that sits on a register inside the body making for a solid connection between the bottom and top of the lifter. The cap will have a retainer usually a wire bale or a Cir-clip. They may be full of oil as some engines like the Chevy pass oil into the lifter to flow up the pushrod and lubricate the rocker arms and cool the valve springs. Others like the Ford FE do not lubricate the top end thru the lifters and pushrods. So as you get into engines you'll see differences like this. When a solid lifter is disassembled there will be no mechanism inside, unlike the hydraulic which is full of stuff.
B) Hydraulic lifters maintain a zero lash once set up. They, also, have a cap in which the pushrod sets like a solid lifter, but this cap is not seated into the outer body of the lifter. Instead it is the top of a mechanism that is supported by oil pressure. The mechanism is retained by a wire bale or Cir-clip just like a solid lifter, so just looking at them isn't a visual aid as to which is a solid or a hydraulic. These work by timing the cut off of the engine oil supply into the lifter's piston and the back force of the valve spring along with some degree of internal leakage. There is an oil supply hole in the body which floods oil to the underside of a piston assembly inside the lifter which has a check valve on its bottom side. As the lobe begins to raise the lifter, the valve spring pushes back shoving the piston into the spring loaded check valve. This allows the plunger to both stay in contact with the pushrod and to allow a dimensional lash, which in measure is about the same as that lash of a solid lifter but contact, while light, is never lost between the parts of the valve train so no noise. As the lifter's body continues to rise on the lobe, the plunger closes the check valve shutting off the plunger's oil supply hole. At this point the plunger is hydraulically locked and can move no further downward. The hydraulic lifter then acts as if it were a solid lifter. As the lifter descends off the cam lobe, the plunger rises from inertia which opens the check valve allowing engine oil pressure to keep the plunger in constant contact with the pushrod maintaining zero lash. The engine oil pressure is less than the closed valve spring pressure so the presence of engine oil pressure on the plunger is not strong enough to force the valve open as the lifter goes around the back (heel) side of the cam lobe.
4) So to find out if you have solids or hydraulics, just get 16 clean towels. Take the retainer clip from each lifter and dump out the insides on a towel. If there's a bunch of stuff in there its a hydraulic. Put the parts back in and lock them with the clip, the less the guts are handled the better.
Now it isn't a good idea to mix cams meant for flat tappet solid lifters with hydraulics and vise versa as the ramps for these two systems are different and cross pollinating parts will lead to increased wear on them. Of course in terms of flat tappet and roller cams, mixing these cams with the wrong lifter will lead to sudden destruction as roller cams have abrupt profiles a solid lifter can't track without digging into the lobe and the wide lobe under a solid lifter would put so much duration into the valve event that if parts didn't collide in the upper cylinder, there would be no compression from the simultaneous opening of intake and exhaust valves. For a roller lifter on a flat tappet cam, it would also be a disaster as flat tappet cams are typically made of cast gray iron which does not have enough surface strength to resist the roller's extreme contact forces. The roller would soon surface fracture the lobes till they ceased to be. Because of the peaking lobe shape, the timing would be really short as the intended sweep across bottom of a flat lifter by the lobe would instead just instantly shove the roller lifter up and then drop it closed with damn little duration.
Bogie
  #20 (permalink)
Old 09-30-2009, 07:30 PM
S10 Racer's Avatar
And there you have it from the pro's. Good luck Dustin.
  #21 (permalink)
Old 09-30-2009, 08:23 PM
Originally Posted by oldbogie
Wow this got long!
Bogie
Thanks for the info, the motor is in my car and it fires and runs. I have been told as well as seen on the thread that I can simply push the push rod into the lifter and If I feel give then it is hydrolic, if not then it is solid.
With that said, I am taking the car to Carsavycook's garage on Friday (it's about 20 miles from my place) and hopefully we can get it figured out.
Thanks very much for the info it is very much appreciated!
  #22 (permalink)
Old 10-01-2009, 09:30 AM
Maybe, once an engine has been fired the lifter is full of oil, it might or not move the plunger with human generated force, it's used to reacting to a valve spring of at least a hundred pounds pushing on it as the cam is moving it up or down. So if it moves when you push against it, then it is a hydraulic. If it doesn't move, then the question is still on the table.
Bogie
  #23 (permalink)
Old 10-01-2009, 10:33 AM
Bogie
Thanks good to know
  #24 (permalink)
Old 10-01-2009, 10:48 AM
Zero lash is when lifter stops ticking while being adjusted , then most cams call for an additional 1/2 to 3/4 turn.
( with engine running back off adjusting nut till tappet starts to tick,then take it down a little at a time till sound stops then add the additional 1/2-3/4 turn)
Thanks for clarifying, and please excuse my ignorance, but what does "0" lash mean?
  #25 (permalink)
Old 10-01-2009, 10:56 AM
Ok, thanks, thats what my beddy was telling me to do, I didn't know there was a term for it.
  #26 (permalink)
Old 10-01-2009, 11:14 AM
OH I just realized you must live in the San Diego area not South Dakota (SD).
I grew up there, my childhood years in Baja La Jolla and my teen years in Escondido when it was a little farm town when Sunkist was the biggest business in town followed by Calvo. Most, if not all, of that is now long gone. Funny small world one of my business partners, whom I met in Seattle, grew up in Guatay at the same time I lived in the SD area.
Say "Hi" to Carsavycook for me. We haven't met but do converse in the virtual world.
Bogie
  #27 (permalink)
Old 10-01-2009, 12:24 PM
Bogie
Will do, it is a small world
  #28 (permalink)
Old 10-05-2009, 06:30 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
I can't wait to get my hands back on it, once he get's the valves adjusted correctly. It is a flat tappet hydraulic lifter cam, and lifter from what I can tell.
It is very impressive sounding for a pump gas engine. It almost runs as good as it looks. (lucky me, eat your hearts out) It will perform better after the next time I get my hands on it.
bogie; It just needed a little increase in timing, and a little carb adjusting. Now it will idle in gear, and sounds like it will perform.
I have it taken care of from this "spot" where we live in this wonderful Country we call home.
sbc pushrod length using stock rockers GMR Hotrodding Basics 3 07-07-2009 09:17 PM
roller rockers for sbc 350 70ChvyNova Engine 4 12-05-2006 11:24 PM
Roller Rockers for a Stocker? coda618 Engine 4 10-28-2006 08:51 PM
PONTIAC ROLLER ROCKER/CAM 455 VALVE ADJUSTING trannsientorca Engine 2 11-10-2002 09:13 AM
Adjusting valves with Roller tip rockers...... joakes Engine 6 10-19-2002 05:54 PM
