SBC adjusting roller rockers. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2009, 02:46 AM
I have 1.6 full roller rockers in my 383, can I adjust them Like I would normally adjust standard rocker arms?
I ask because I did, then I heard a ticking from the rockers, either this is normal or they are not adjusted correctly.
Thanks
Dustin
Old 09-27-2009, 06:15 AM
With roller rockers (full roller I assume) some noise is inevitable.They are adjusted exactly the same as stock rockers.
Old 09-27-2009, 08:52 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Thanks
Dustin
Are you using a hydraulic or solid cam/lifters?
Old 09-27-2009, 10:37 AM
I think i have a hydrolic flat tapit cam
Old 09-27-2009, 12:44 PM
S10 Racer's Avatar
You will need to know for sure what you have before you can adjust it correctly. A hydraulic cam/lifter combo adjusts to "0" lash while solids require a lash using a feeler gauge (somewhere around .022). If you have solid lifters and are adjusting it like hydraulic, things will go wrong in a hurry.
Old 09-27-2009, 10:49 PM
I do have solid lifters.
Old 09-27-2009, 11:01 PM
Crower Ultra Performance Compu-Pro Performance Level 4 Camshafts Camshaft - Hydraulic Flat Tappet - Advertised Duration 288 - 296 - Lift .497 - .504 - Chevy - Small Block
Brand: Crower, Mfr Part#: 00244
Sorry! Currently no stores sell this product.
Product Details
Specifications: * Advertised duration: 288 intake/296 exhaust * Duration at .050 in. cam lift: 234 intake/246 exhaust * Gross valve lift: .497 in. intake/.504 in. exhaust * Lobe separation: 112 degrees * Recommended compression ratio: 11:1 * RPM range for 350 level four: 2000 to 6200 rpm * 11:1 compression ratio recommended
my cam specs
Old 09-28-2009, 03:28 AM
S10 Racer's Avatar
Product Details
my cam specs
While using solid lifters with a hydraulic cam has and is being done, it's not recommended but since you have solid lifters, you will always have a "ticking" sound because you have to adjust these with a lash setting. Because of the mismatch, I would set the lash at .022 on both intake & exhaust. The only way to get it quite is to change to hydraulic lifters and then you can adjust them to "0" lash.
Old 09-28-2009, 09:27 AM
When you say solid lifters, do you mean they are not roller lifters? Or can hydrolic lifters also not have rollers.
When you asked whether they were solid or hydrolic I thought ou were asking whether they were roller lifters.
If I have the right lifters with my cam how would i adjust them?
I can contact the builder to make sure, but I am pretty sure he matched the cam and lifters up properly.
Old 09-28-2009, 09:56 AM
.....I do have solid lifters......I think....lol
Old 09-28-2009, 12:49 PM
S10 Racer's Avatar
In one of your previous posts you said you have solid lifters but then spec'd your cam as being hydraulic. That was my concern. We are talking lifters now, not rocker arms. If you have a flat tappet cam, you either have hydraulic or solid lifters. You need to know which one of these you have before you can adjust them because they are adjusted differently. You can look at the top of the lifters and if you see two small wires running across the top (one wire on each side of the pushrod), it's a pretty sure bet you have solid lifters. If there is a snap ring instead of the wires, it's a pretty sure bet you have hydraulic lifters.
Old 09-28-2009, 02:43 PM
Thanks, I will get on it this weekend.
If I have hydrolic lifters I should use a feeler gauge to adjust them?
Old 09-28-2009, 03:47 PM
S10 Racer's Avatar
NO, if you have hydraulic, they will be adjusted with "0" lash. If they are solid, they get adjusted with a feeler gauge. You may want to pick up a book on engine rebuilding or search thru Hotrodders for articles related to valve adjustment. There is plenty of info on here for that. The valve adjustment needs to be correct so it's important to get it right, but again, you HAVE to know what kind of lifters you have first. Good luck and keep us posted.
Old 09-28-2009, 04:57 PM
Thanks for clarifying, and please excuse my ignorance, but what does "0" lash mean?
Old 09-30-2009, 12:35 AM
Pretty much every stock-type hydraulic lifter I've ever seen has had that kind of straight-sided wire clip at the top.
sbc pushrod length using stock rockers GMR Hotrodding Basics 3 07-07-2009 10:17 PM
roller rockers for sbc 350 70ChvyNova Engine 4 12-06-2006 12:24 AM
Roller Rockers for a Stocker? coda618 Engine 4 10-28-2006 09:51 PM
PONTIAC ROLLER ROCKER/CAM 455 VALVE ADJUSTING trannsientorca Engine 2 11-10-2002 10:13 AM
Adjusting valves with Roller tip rockers...... joakes Engine 6 10-19-2002 06:54 PM
