sbc aluminum 303Hp & best auto trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2009, 07:23 AM
Project - 1970 Camaro one owner
Looking to build a quick streeter with decent gas mileage (13 mpg sux!).
Searching for a low mileage aluminum 303HP smallblock that will hookup to latemodel auto tranny. I would appreciate tech leads on How To source the right parts.
I am looking to run stock motor (with headers, chip, cold air pack), gears and slicks for 1/8qm@8.25et.
Have stock internals goodwrench 350 (manifild, 650cfm,headers,recurved dist,battery in trunk, slicks, loose converter, elec fan) in it now and run <2sec/60 ft -- 8.96 best and 9flat consistent 1/8th -- with 3.08 gears!
Old 02-05-2009, 08:22 AM
SSedan64's Avatar
From reading other threads/posts, I think you have to use an ECM & harness from a donor vehicle that has a manual trans if you're not going to use the electronically controlled trans. Otherwise it will throw all sorts of codes from not having input from the trans.
Trans for 500+ HP SBC in a 3500 lb car nastynova Transmission - Rearend 11 12-05-2006 11:08 AM
ALL Aluminum SBC???? 1Fine69 Engine 22 03-05-2006 11:05 PM
Any Hp Gains Aluminum Or Cast Water Pump Sbc jsteve068 Engine 4 01-16-2006 12:54 PM
GM Auto trans identification help? Pantera II Transmission - Rearend 1 12-02-2002 04:02 PM
late model auto trans question crazy larry Transmission - Rearend 2 11-23-2002 09:20 AM
