Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC Balancer Depth ?
Old 01-08-2013, 08:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 454 Rattler View Post
Hi guys !
Could anyone tell me if this balancer is in the correct position ? It seems like it's in too far to me. The crank and water pump pulleys line up okay. This is on a 350 with a SHORT water pump.
I'm adding power steering to my 36 Ford with a Mustang II rack. I'm ordering a triple groove pulley and will probably space the steering pump out to match the outer groove of the crank pulley.
Any thoughts on the balancer depth ?
THANKS !!
454 RATTLER
As best as I can tell, yours looks OK. The end of the damper snout bottoms against the crank timing gear, so it can't go on too far unless you happened to grab a short snout damper from a SBC equipped w/a EFI/ECM reluctor ring (below, left).
The Following User Says Thank You to cobalt327 For This Useful Post:
Camaro_Nut2001 (01-09-2013)
