SBC Balancer Depth ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2013, 03:48 PM
454 Rattler's Avatar
NEVER SATISFIED !!
Hi guys !
Could anyone tell me if this balancer is in the correct position ? It seems like it's in too far to me. The crank and water pump pulleys line up okay. This is on a 350 with a SHORT water pump.
I'm adding power steering to my 36 Ford with a Mustang II rack. I'm ordering a triple groove pulley and will probably space the steering pump out to match the outer groove of the crank pulley.
Any thoughts on the balancer depth ?
THANKS !!
454 RATTLER
Name:	power steering pully harmonic balancer 004.jpg
ID:	70404   Click image for larger version
Name:	power steering pully harmonic balancer 005.jpg
ID:	70405   Click image for larger version
Name:	power steering pully harmonic balancer 006.jpg
ID:	70406   Click image for larger version
Name:	power steering pully harmonic balancer 008.jpg
ID:	70407   Click image for larger version
Name:	power steering pully harmonic balancer 009.jpg
Old 01-08-2013, 04:12 PM
I can't say anything about the pulleys, but the dampner looks to be about the same depth as mine.
FWIW,
ssmonty
Old 01-08-2013, 05:19 PM
It looks right in the picture. Did you use the balancer installer when you installed it? The bolt is torqued to 60 lbs.
Old 01-08-2013, 07:26 PM
327 / 350 hp's Avatar
SBC balancer depth
Hi 454, just a suggestion, but have u looked into pressing the pulley further on pump with p/s tool.. also depth looks good to me if bolt is torqued....jim
Old 01-08-2013, 07:53 PM
Rattler I know what your saying I just finished a cam replacement on my 350. Mine went on the same distance, showing the timing mark indicator sticking out past the damper which made me also think it went on to far but evidently it's right. I'm wondering if the stock damper would be a little wider.
Old 01-08-2013, 08:04 PM
327NUT's Avatar
If the balancer is installed with the proper tool you just keep turning the hex bolt until it comes in contact with the machined shoulder of the crankshaft.....you can't press it on any further.
Unfortunately some guys still use the BFH and a piece of 2X4 and slam away.....still until you bottom it out on the crank....not the preferred or proper way to install mind you, bad on the thrust surfaces.
Old 01-08-2013, 08:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 454 Rattler View Post
Hi guys !
THANKS !!
454 RATTLER
As best as I can tell, yours looks OK. The end of the damper snout bottoms against the crank timing gear, so it can't go on too far unless you happened to grab a short snout damper from a SBC equipped w/a EFI/ECM reluctor ring (below, left).
The Following User Says Thank You to cobalt327 For This Useful Post:
Camaro_Nut2001 (01-09-2013)
Old 01-09-2013, 06:42 AM
Camaro_Nut2001's Avatar
Drag Racing Lover
Last journal entry: '68 Impala Project
You would know if it was cause the balancer wouldn't go up against the crank gear due to hitting the timing cover. It looks right to me but either the p/s pulley isn't all the way on or you need a different crank pulley, probably the crank pulley. JMO.
Old 01-09-2013, 08:41 AM
NEVER SATISFIED !!
Thanks for all the replies. I did use the proper tool to install it and I torqued it to 60 lbs. After reading these replies I feel much better.
As I said , I've ordered the new pulley (3 groove) and I'll work with the power steering to get it worked out.
Thanks again for the quick action guys.
454 RATTLER
Old 01-09-2013, 09:39 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
After looking at your crank pulley again, it looks to be for a SWP, like used on cars '68-back and trucks from around '73-back.
The top photo shows a 2-groove SWP pulley. Bottom is LWP. The LWP crank pulleys are always dished.
In case yours has the p/n on it: Double groove 3744043BA or 3850838BG (it's 7-” dia., 1-” depth, inner groove is flush with mounting holes).
Old 01-10-2013, 07:48 AM
NEVER SATISFIED !!
Yes, it's a SHORT waterpump and the pulley is like the first one Cobalt327 posted.
I ordered the triple groove lower pulley as I'm told that the PS belt should run off of the third (outer) groove on the lower pulley.
What worried me was the fact that there won't be much of the timing mark showing. I guess I could change that too.
I've always liked making little mods and all kinds of brackets and unique things.
Thanks guys !
454 RATTLER
Old 01-10-2013, 09:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If this combo of PS pump, SWP and pulleys has run as a unit before you shouldn't have any problems once the 3-groove pulley comes in. If not, just be sure the PS pump isn't for a LWP set up.
BTW, there's an add-on factory outer "3rd" groove pulley that was used by Chevy. Works on a 1- or 2-groove factory-type pulley... but you already have your 3-groove pulley ordered, so moot point.
SBC 400 balancer Greg T Engine 13 08-02-2010 07:34 AM
Harmonic Balancer SBC HELP sexypizzaman Engine 2 02-10-2008 12:52 PM
SBC Balancer Help johns79z28 Engine 6 02-27-2007 10:48 AM
sbc balancer question STATUTORY GRAPE Engine 8 07-11-2005 05:59 PM
Balancer sbc atlantis Engine 14 02-14-2005 01:09 AM
