SBC Balancer Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2007, 06:24 PM
SBC Balancer Help
Can someone help me with a question about balancer size?
I am putting my engine back together after a long illness and
need to know the importance of using different sizes.This
is a SBC 350 4v turbo 400.It is a 350 2 bolt block with new
.020 forged pistons,new 270h cam ,pete jackson gear drive
aluminum heads,roller rockers ,studs and plates not an all out
engine but much more than stock.Will be put back in my 79 Z-28
no smog.I do have a 6 3/4 and an 8" and am not sure what would
be better or if it would matter.Thanks
John
Old 02-26-2007, 06:44 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
It should not matter if they are both for internal balance engines ( the 400 sbc used external balance). I like the smaller size myself.
Old 02-26-2007, 07:25 PM
Thank you for the reply.I will use the smaller one since it
is sfi certified. John
Old 02-26-2007, 11:15 PM
fast68's Avatar
likes chevy trucks & boobies
87-up were external again, 305 and such engines
i personalyl prefer 8" balancers, most of the 4bbl 350 engines were 8"
and some werent, and were instead fitted with the widest balancer, identical in appearance to the 305 ones, 6 and 3/4 OD
good luck
Old 02-27-2007, 12:11 AM
The 8" dampers reputedly tame torsional vibration better than the smaller ones, so cam timing stays more stable, yielding better power.
Old 02-27-2007, 06:55 AM
good luck
Thats 86 up and they are external on the rear and neutral on the front.
And using a gear drive it may be better to go with the 8 inch balancer as the gear drive will tend add more harmonics then using a timing chain set up.
Old 02-27-2007, 10:48 AM
Harmonic Balancer Size
Thank you everyone for your help!!!
Since I will be doing some Bracket racing
and spend more time on the street
an 8" seems the way to go.
John
SBC balancer measurements ? Vortech 4.3 Engine 0 04-22-2006 04:56 AM
sbc harmonic balancer 84cutlass Engine 2 04-10-2006 08:38 AM
which Harmonic Balancer for sbc? big or small? 406 ss monte Engine 1 03-02-2006 06:15 PM
sbc fluid dampner (balancer) or not? help 406 ss monte Engine 10 03-21-2004 07:18 PM
sbc 327 vs 350 Harmonic Balancer Question Ted's37 Engine 3 07-14-2003 04:10 PM
