SBC block grinding? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2002, 09:50 AM
The Vandal's Avatar
Engine Tech Addict
Post SBC block grinding?
3970010 4-bolt
If you look down the bores to the top of the main webbing, there are small holes (the largest is about .25) where the tops of the inner main bolt holes are - I can barely see the ends of the inner main bolts. It's like this on 4 bolt holes and my machine shops says it's common and no big deal. Do I leave them alone or grind them smooth to eliminate possible cracks in the future? Of course if I grind I make the holes bigger and the block is fully machined and ready to go so I would hate to introduce all those metal particles to it. The engine will be 388 CI. Goal HP is 400 in a 1970 Chevelle street car. Thanks guys - you rule.
The Vandal
Old 09-15-2002, 05:15 AM
The Vandal's Avatar
Engine Tech Addict
Post
bump - it's been a week and I'm sure someone here can answer this...........
The Vandal
Old 09-15-2002, 07:10 AM
NAIRB's Avatar
Post
I would go ahead and debur this hole, just radius the edges and polish it smooth. At the 400 hp level, especially on the street, you won't have a problem if you don't do this, but deburring a sharp edge is always a good idea. You can always tell if a customer's car hooks up and makes good power when he brings the engine into freshen it up, hot ones that hook will form cracks in the bottom end. Usually where the main webbing meets the pan rail right in the corner, I used to radius this area and polish it smooth.I don't really remember the inner bolts cracking, but it doesn't hurt to smooth out jagged edges.
Old 09-15-2002, 09:10 AM
4 Jaw Chuck's Avatar
Post
You can leave it if you want, deburring is a good idea so don't worry about enlarging the hole. Either way you can't hurt anything, I would just leave it if it meant I would have to clean the block again.
— Han Solo
