SBC Break In - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2003, 11:40 AM
Post SBC Break In
A Question for the Engine Builders.
What do you reccomend for break in procedure for a 383 Chevy Stroker with a seasoned block (with complete machining done) with all other internal parts being brand new ? Thanks for the help
Joe
Old 04-16-2003, 12:06 PM
Post
Here is what GM recommends on their Crate Engine:
1. SAFETY FIRST! If the car is on the ground, be sure the emergency brake is set, the wheels are chocked, and the transmission cannot fall into gear.
2. Be sure to check the oil level in the engine and prime the oil system
3. Run the engine between 2,000 and 2,500 RPMs, with no-load on the engine for the first 30 min.
4. Adjust the distributor timing roughly by hand for a quick start up and smoothest idle possible.
5. Adjust the carburetor settings, if necessary.
6. After the first 30 minutes of the engine running, set the ignition timing (see install ignition section for timing specifications).
7. Drive the vehicle with varying speeds and loads on the engine for the first 30 miles. Be sure not to use a lot of throttle or high RPM.
8. Run five or six medium-throttle accelerations to about 5,000 RPM (55 to 60 MPH), then letting off in gear and coasting back down to 20 MPH.
9. Run a couple hard-throttle accelerations up to about 5000 RPM (55 to 60 MPH), then letting off in gear and coasting back down to 20 MPH.
10. Change the oil and filter with 10w30SG oil and PF1218 AC Delco oil filter (PN 251605610
11. Drive the next 500 miles normally, without high RPM's (below 5,000 RPM), hard use, or extended periods of high loading.
12. Change the oil and oil filter again.
13. Your engine is now ready for many happy cruising miles!
Old 04-16-2003, 01:17 PM
Post
Small Block,
Thanks for the help
Joe
Old 04-16-2003, 02:06 PM
bullheimer's Avatar
NEVER use credit cards!
Post
who's gonna argue mit der jeneral???
Old 04-16-2003, 02:38 PM
4 Jaw Chuck's Avatar
Post
I can go with that.
— Han Solo
