Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC breathing set up
Old 04-22-2009, 09:20 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
It upsets things likely because you have low vacuum. Causes of low vacuum can be many things such as a vacuum leak, low initial spark timing, low compression, camshaft too large, leaking valves and rockers out of adjustment to name a few.
