sbc budget build - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2008, 03:58 PM
79monster's Avatar
sbc budget build
got a 4 bolt 350 sbc with spun bearing, what can i rebuild it with on a budget to achieve 300 to 350 hp???
Old 10-28-2008, 02:00 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Get a low cost rebuild kit on ebaY (good ones list name-brand components), have a minimal head job done (no new valves or guides unless absolutely necessary), minimal block work (hone, bore only if necessary, surface deck only if necessary). For that power range on a budget get an Edelbrock Performer cam/manifold/carb combo.
Old 10-28-2008, 06:03 PM
This place has good Prices on SB Chevy 350 Rebuild kit's . And you can do up-grades on the Parts . Such as Bigger Camshafts Better Pistons and Rings H/V Oil Pump and more . But before you can order one of the kits . You need to know the under cut of the crank and over bore of what your block will be . Also it is always a good idea to have all the rods Rebuilt with ARP Bolts . www.northernautoparts.com/
Old 10-29-2008, 02:28 AM
327NUT's Avatar
......and on a further note, most machine shops want the pistons you're going to use BEFORE they final hone the block. So have them check the cylinder wall taper and tell you .030, .040 etc. Then you can order your parts, and yes, Northern Auto has some good deals. Good luck.
Old 10-29-2008, 08:21 AM
FEDDO's Avatar
X2 on northern.
Opinion on 400 SBC Build Up. ezobens Engine 21 11-18-2013 08:49 AM
sbc build options nskeeter99 Engine 15 10-31-2008 08:48 PM
SBC Motor Build weshova Engine 4 10-21-2008 11:10 AM
My sbc 400 build up, please review Guitar Charlie Engine 13 06-17-2004 09:06 AM
Low budget 350 Build 39deluxe Engine 1 03-14-2003 07:05 PM
