sbc build - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2009, 08:45 PM
mikey1476's Avatar
sbc build
hi hoping to get some advice on building my 350.so far i have crane 488-510lift-234-244 cam,edelbrock super victor intake,PATRIOT ALUMINUM HEADS 2.02 V 64CC,edelbrock 650 carb,block is a 79 out of camaro.any input would be great as this is my first motor build,i'm hoping to get 375 hp.thanks for your help.
Old 02-19-2009, 10:45 AM
Are you using stock bottom end components (rods, crank) are you looking for a piston recommendation/engine kit. Looks like you have most already.
Old 02-19-2009, 12:07 PM
mikey1476's Avatar
i have stock bottom end,looking at flat top pistons that are 30 over size,before i put it all togather what am i missing or should i add,its going i a 79 camaro mostly street use,couple times a year to the drags
Old 02-19-2009, 12:23 PM
327 / 350 hp's Avatar
Sbc Build.......
Hey Mikey , sounds like you have great parts there, I would suggest a steel crank and a roller cam with that lift. .488- .510. good luck.
Old 02-19-2009, 12:56 PM
It`s nice to put a nice piece together however, keep in mind that the first thing you need to do is to make sure you get the internals balanced before the assembly. You can ruin your good parts in the long run if you do not balance the assembly. A steal crank is the way to go and Eagle has come a long way from the past, they offer a real good price on cranks for up to 800 ponies. Good luck with your motor.....
Albert
Old 02-19-2009, 01:05 PM
wrong intake. you need a dual plane. look at the performer rpm intake.
not happy with that carb. get a 750 holley.
you will need 10:1 cr, 3.73 gear, and a 2800 stall with that cam.
Budget 400 SBC build up elcamino74ss Engine 15 02-02-2011 07:22 PM
What kind of strokers can i build with a 400 sbc????? Adolfo1955 Hotrodding Basics 10 12-19-2008 04:40 PM
sbc build options nskeeter99 Engine 15 10-31-2008 07:48 PM
383 sbc build jake_arcticcat Engine 2 05-10-2008 04:02 PM
My sbc 400 build up, please review Guitar Charlie Engine 13 06-17-2004 08:06 AM
