Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sbc build
Thread: Sbc build
Old 11-20-2012, 06:27 AM
stackitup_91 stackitup_91 is offline
Sbc build
i have some questions about a build that i am in the process of Building. i Wanted to know how much horse power you all will think i will be at with this combo (TO THE TIRE) and any advice about the cam that i am using,
compression is at 10-1 I Have a 350 bored .40 over
Comp cam 292H, (501/501) Lift 1.5 ratio Roller tip Rocker Arms
VORTEC HEADS that have been modified with screw in studs. double springsswitch the heads have been machine for and they have been ported and polished
Edelbrock RPM airgap Intake
Flat top Pistons Eagle Connecting Rods (Standard Length 5.7)
700R-4 trans
650 quick fuel Carb
3.73 Rearend Gears and hooker headers..
whats would be the best cam to go with for this build?? I will be driving the car twice or 3 times a week, this motor will be going in a 1984 z28 Camaro my goal is to get at least 350 hp to the tire
Thank you and responces are appriciated
