Use the comp cams small hyd thumpr cam it will sound good and make pretty good power. But not real smooth at idle it will lope pretty good.
They make good power and sound good dont work on all engines but it sounds like you could run the small thumpr without it any issues. Sep for maybe some carb tuning. Alos most dyno resluts put the thumpr above other cams inhp because the thumpr design produces good peak hp number other cams can produce more average hp. Which is better for truck build with 3.08s
You can hear them on youtube alot of people have vids of the sound.
