SBC Build, Some Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2009, 07:37 PM
Hi everyone.
I am a refuge from some of the Corvette forums on the web, and I'm looking for some honest advice on my new engine build. If you have never been on one of these forums, everyone will tell you to buy the most expensive parts for your engine; but to me, it's still just a sbc, and I don't feel it's necessary to spend a lot of money to build a strong engine.
OK, with that said, here's what I have and what I want to get too. I am buying a 406 from a friend who has in in his F body running a carb. I am just buying the short block, he is keeping the heads.I want to make it fuel injected, and I am thinking of using a converted LTx intake, or maybe a Miniram. The heads will be either TFS or AFR, but I am leaning towards the TFS 195 heads. Not sure about the cam, but I want it to be mild and very streetable. I may have to take the car though emissions at least one more time before I can get classic plates.
So here are my questions-
What size cam would work best? I want it to be a hydraulic roller. What size injectors to run? I have had people tell me to run 30lb to 42 lb, any ideas? Also, where to buy injectors at a good price?
Sorry for the long post, and thanks.
Randy
Old 05-19-2009, 08:08 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by RandyJ75
I want to make it fuel injected, and I am thinking of using a converted LTx intake, or maybe a Miniram. The heads will be either TFS or AFR, but I am leaning towards the TFS 195 heads. Not sure about the cam, but I want it to be mild and very streetable.*snip* What size cam would work best? I want it to be a hydraulic roller. What size injectors to run?
For emissions compliance, I think if it were me, I'd contact whoever it is that's going to supply the EFI controller- be it F.A.S.T., Accel, MSD, Edelbrock, a self-soldered MegaSquirt (prob. cheapest- and said to work good) or whomever.
I would work closely with them to tailor a system that will meet my requirements- this would include cam specs that would then be run past the techies at the cam manufacturer of my choice to get their input as well as injecter size, etc.
Old 05-19-2009, 08:16 PM
I guess I should have mentioned that this engine is going into my 1990 Corvette, which has a computer.
Randy
Old 05-19-2009, 08:41 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A computer, but it will not, as-is, handle all your proposed changes.
So, get w/the chip manufacturer and as above work w/them to tailor a chip.
Old 05-20-2009, 09:22 AM
Good advice. I have a 90 Vette too, so if you have any questions, let me know. Get ALL your mods baked then we can look at injector specs. Need cam size, rocker ratio, etc....
Old 05-20-2009, 02:25 PM
OK, I know I need a custom chip, but I need to get a cam picked out first. This is were I'm lost, as I barely understand the differences in cams. I spoke to a tuner I know, and he told me figure out what I want, and he can then make some recommendations on size of injectors.
Old 05-20-2009, 03:13 PM
Hi everyone.
Randy
You answered my first question in another post which was the year "1990".
That means this is an L98 which is a Gen 1 with TPI. That tosses LTx intake out as its for reverse flow heads and does not have coolant return passages compatible with Gen 1 heads. You need to think around your existing TPI if you want to keep costs down. The system you have is OBD1, to get into an OBDII system of the LTx engines takes a new computer and matching wire harnesses, which is a lot of work and expense. Doable, but you've got to understand it ain't a cheap nor simple swap if you've never done it before.
The 406 is going to take a custom chip in the existing computer. The question of 30 or 42 pound/hr injectors comes to how much duty cycle you want to run. A 30 pound/hr injector will be on for more time than a 42 so it will run hotter and last less long, that probably is the answer without doing the math to see if 30 will support that engine even if on all the time. The chip, the injectors, the cam all need to be selected together. The LT4 HOT cam will work with a chip but it will take a batch flow TPI like you have to the edge of emissions compatible. The LTx engines used sequential injection so the injectors were off during overlap, so heavy loads of raw gas were not going straight out the exhaust as it will with your's. This can be compensated for with TPI by using AIR injection into the exhaust and fresh cats. Or, heaven forbid, a milder cam such as the either the standard LT1 or 4 or an equivalent. The other trick with TPI is to use a cam with a long LSA, this minimizes or eliminates overlap which just does away with raw fuel going out the exhaust.
Your big problem will be compression, while small chamber heads do better at power generation and emissions reduction, to keep the compression at something pump gas will handle would require a dished piston. Of these the best design selection is the "D" dish as these present a highly effective squish/quench surface while managing the overall CR with the dish below the valve/sparkplug pocket. The other solution would be a large chamber head with a flat top. But these are unfriendly to emissions and aren't as efficient at lower RPMs due to a lack of turbulence and slow (by milli-seconds) burn times. These need more advance which leads into higher NOx. Sometimes this seem like a dog chasing its tail, but there are "better" solutions hiding in there.
Bogie
Old 06-03-2009, 02:07 PM
Thanks for the replys. I have seen LT1 intakes modded to work on a gen 1 engine/heads; I am just not sure if it would flow enough to work on the 406. As for emissions, I believe I am done w/ them. I spoke to my friend w/ the engine, and he said that heads w/ a 72 cc camber size should give me about 10:1 compression, which I think should be good for my goals.
A couple of questions; what would the longer LSA do for performance? Isn't the LT4 cam a little small for a 406? As for the injectors, doesn't adjusting the fuel pressure help w/ the amount of fuel delivered? I mean, it seems like a 42 lb injector is a little big for a basically stock engine?
Thanks for helping a noob out guys.
Randy
Old 06-11-2009, 08:08 PM
Any help w/ my questions, guys?
What to consider when choosing your first SBC build? CandiMan Engine 16 05-25-2009 08:50 PM
SBC rebuild research questions. V8 Super Beetle Hotrodding Basics 13 02-17-2009 10:59 PM
400 SBC Build - Help & Suggestions Needed S10 Racer Engine 3 03-19-2008 11:02 AM
sbc 350 build up questions b/w72 Engine 9 01-08-2004 06:12 PM
clutch matchup questions for SBC to T- 56 hotrodf1 Transmission - Rearend 0 12-17-2003 09:49 PM
