Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc burning oil
Thread: sbc burning oil
Old 10-23-2008, 09:29 AM
The Factory Man The Factory Man is offline
Originally Posted by alittle1
You did say you checked the modulator valve on the side of the trans for any trans fluid in the vacuum line.
There would be a complaint of loss of transmission fluid if the modulator valve was leaking oil into the vacuum line. He is apparently using engine oil, about 1 qt every 100 miles. I don't see why you directed him to the transmission modulator valve if in fact his transmission even uses one?
