sbc burning oil - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 11-03-2008, 02:13 PM
good grief!!!
you wait till post #30 to tell us you run nitrous!!!!!
pull the plugs and carefully inspect them that all 8 are indeed equally yuch with oil deposits indicating the pcv source....
if some are clean(er), do a compression test now.....
once the pcv oil supply is cut off the chambers and plugs tips electrodes will clean themselves given enough miles....
Chevy 6.5 Diesel has no oil pressure again!!! dorksrock Engine 12 09-02-2012 09:51 PM
[help] assembly oil priming (sbc) KNanthrup Engine 16 10-23-2008 06:56 PM
Correct Oil Pressure for SBC 350 Houman SS '70 Engine 13 03-16-2005 03:01 PM
Oil Preshure ve3ham Engine 9 10-28-2004 03:36 PM
A little humor Kevin45 Hotrodders' Lounge 8 10-21-2004 01:47 PM
