SBC cam degree - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2012, 06:44 PM
SBC cam degree
I have a small block Chevy that i am planing to but a mechanical roller solid cam. I want to know if it is necessary to degree the cam or if i can skip doing it?
Old 02-10-2012, 07:39 PM
8-71 blown 461 Rat on E85
Dot to dot is one thing...degreeing gets the icl on par with the cam card for best performance.What you need to be concerned with is piston to valve clearance on the exhaust side during the overlap period.Typically a non issue with a oem smogger cam..but you did mention a solid roller..and the p/v clearance check is a must.A safe bet is .080" on the the intake and .100" on the exhaust depending on your spring control.
Old 02-11-2012, 12:45 PM
techinspector1's Avatar
Wiki Edits: 326
Do whatever you wish, but it is my feeling that if you don't care enough to do it right, you should probably take up another hobby.
Old 02-12-2012, 07:55 AM
x2 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
How to degree a cam... XNTRCI-T Engine 3 09-17-2010 03:39 PM
18-degree heads or 23-degree Showa72 Engine 2 03-09-2010 03:11 PM
SBC 18 degree head compared to 23 degree head powerwise? sb72elcamino350 Engine 7 03-09-2010 02:01 PM
Using 18 degree pistons in a 23 degree block S10 Racer Engine 2 03-11-2008 03:52 AM
To Degree The Cam Or Not ? ? ? SCHOONER Engine 8 12-18-2006 01:10 PM
