Sbc cam id #115871 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2013, 01:52 PM
Sbc cam id #115871
Hello guys !
I recently bought a 79 Camaro Z28 with a 350 sb. I have no idea what the cam shaft is and would appreciate any help out there. There is no name just a bunch of numbers/ stamped on the end is 115871 under that is 252509 or . casting numbers and letters between lobes are CWC H5 31 1539.
thanks
Michael
Poland
Old 03-12-2013, 03:06 PM
BOBCRMAN@aol.com's Avatar
White box (generic) .339 int .355 exh LOBE lift. 244intake 254 exh duration
Old 03-12-2013, 03:18 PM
thanks, but what means "White Box" - no name ?
I had problem with engine running in this car so that's why i put out this Cam.
Car have some modifications ;
roll cage, SBC350 with Holley Street Avenger 80670 Dual Feed, Edelbrock Performer RPM (1500-6500) intake,MSD dist.,Comp Cam roller rockers, Headers, B&M TH400 trans, new sparks, cables,).
I had this problem before i put out cam ;
Engine runs smoothly on idle (about 1000rpm) but when i put in gear it drops to 500rpm and idle rough, and dies when i turn steering wheel, but when i push gas pedal car runs and drive.
Intake is Edelbrock Performer RPM (1500-6500), . I changed carb,set ignition timing, fuel level, idle air/fuel mixture Edelbrock Performer Intake ( idle-5500) but problem was the same.
This was a cam problem ?
If yes, what cam should i put for daily driving with Edelbrock Performer Intake (0-5500) and the same carb.
Thanks
Michael
Old 03-12-2013, 03:40 PM
Yes, a cam problem. Way too much duration for a mild engine and a real problem trying to get it to idle or run at 500 rpm. That would take some carburetion work and motor would still have very little power below 2400 rpm.
A "white box cam". In the USA most of the less expensive camshafts are manufactured by two or three mass production grinders. Then packed in white boxes that are re-sold by the retailers under dozens of different brands. Just print a name or label on the box.
Any cam with 230 or more duration @ .050 will have similar problems on a mild engine. For a driver/cruiser type car. Auto trans p-steering/brakes. stock type rear end. Go with a short duration high lift cam.
Old 03-12-2013, 03:42 PM
Banned
Thanks
Michael
Thats not a good cam for that application, for a good daily driver just get a mild cam like the E1128 cam from Elgin. Elgin, Hydraulic Flat Tappet Camshaft, Chev SB - Competition Products
you'll also need to replace the lifters and should probably do the springs as well. The pushrods may be okay- you may need +.100"
SBC Cam I.D. Greg T Engine 8 02-25-2014 07:54 AM
sbc cam ? gunsaler111 Engine 3 01-25-2012 09:38 PM
Can I use this cam in my SBC? Zeeb Engine 2 02-22-2011 03:08 PM
SBC Forced Induction "Cam"? What cam to use? 1wikednova Engine 11 03-11-2010 09:50 PM
Do oem 350 sbc roller cam's take the same cam bolts as older ones? eric32 Engine 5 04-20-2009 05:12 PM
