You need two things.......
9.5:1 or better CR........a cam with an LSA of 110 or LESS.
Don't know what kind of car this GM engine is going in........the little roadster you have a picture of? Important because.....if its a light weight car to begin with a rad cam will be more drivable. The cam you had before had ALOT of duration and a wide LSA. Shorten up on both. You know what a circle/dirt track engine sounds like? You like that kind of idle? 106-108LSA......215-225 intake and 220-230exhaust duration@050. Small lift(save your valvetrain) Delta Cam can grind you a custom grind for the same money OR LESS than Compcam...and give good input 6sally6 |
Summit racing offers a cam that has .216 duration @.050. It works with low compression 350's and provides a lopey idle without the loss of low end torque. The rest of your combo matches it well so it'll work for you. After you get it installed you have to get the tune correct for it to lope. The 1102 that your removing would you be willing to sell it and the lifters? You would have to keep the lifters in the exact order they are on now but that's not very hard. If you want to do so, shoot me a PM.
http://www.summitracing.com/parts/SUM-1065/ |
Isky cam #201268. It will have the sound at idle you want and is very responsive. Degree it in for best results. 103 intake C/L.
You will want to recurve the distributor after installing this cam. |
cam/carb
the carb is the same as it came out of the box.. yes its goin in the bucket, it wt's about 1800#. spoke to the tech rep and he said it between a smooth and rough idle cam... only took 2 hrs to get through... a few yrs ago, when i replaced with a ruff idle the tech said summit's are built by comp.. he did suggest the comp 270/270 but its very close to the summit K1104 and half the price.. I don't cheap out on my car but i don't blow money either just for the name..
Elgin sells the same cam as all the rest but at a better deal, the 216/216 cam with a 106lsa and .450" lift. It's exactly what you need, its a lopey street cam that is very easy on the valvetrain. It makes pretty good torque too. Not a cam for big power numbers but is very nice in most street rods. I've ran this cam with 1.6 rockers and its wonderful for mild stockish engines. It really should have headers used with it though. Comp sells that cam as the 274h06, I forgot the elgin part number but they're all the same. You may want to consider 1.6 rockers with it if you have decent heads as it'll pick up some power with this mild cam. |
These guys(above) give good/right on advice.
I might add one thing. If you get a cam(like suggested) try to get bigger exhaust duration than intake. It will give the engine more of a "thump" sound at idle because the exhaust is closing a little later. Good also if street rod with mufflers....gives a fraction more time for the exhaust pulse to go thru the restrictive muffler. Listen to the "mutha-thumpa" grind by CompCam. Long exhaust duration and tight lobe separation. Custom grind cams are same or less money than shelf item cams. Howards...Delta...Bullet...If you order....takes about the same length of time too. 6sally6 |
Might want to check this out:http://www.summitracing.com/parts/HRS-CL112431-06/ Sounds like it fit's the bill!
The Elgin 1785 is the same as the Crane 274HO6, .450, 274*, 218* @ .050, 106* LSA. Here's the Elgin cam/lifter kit for $99.99 at Northern Auto Parts
Here's this cam in a stock Goodwrench 350 with an Edelbrock Performer and a 600 Holley with headers: Ed Last edited by BigEd36; 04-18-2012 at 08:36 PM. |
Give this a listen http://www.youtube.com/watch?v=1pE_WeIInNs I used several of these "back in the day" 350HP 327 L-79 always loved them.
My opinion may have been clouded by the guys @Delta Cams. Great after the sale service, recommendations on aplication, and a pretty good price. Hard to beat $99.00 bucks though!!! 6sally6 |
http://www.summitracing.com/parts/SUM-K00172/ |
The Howards cam mentioned by JeffB is basically identical to the Isky 201268 mentioned by F'Bird88, just 1* @ .050 difference. Howards is a quality piece, but a little lower priced than the equivalent Isky. |
| SBC cam selection | 2005vette | Engine | 1 | 04-19-2011 02:06 PM |
| Cam selection help - 400 sbc | JimNut | Engine | 4 | 11-30-2010 03:27 PM |
| cam selection for sbc 350 | chitowns350 | Engine | 6 | 07-08-2010 02:09 PM |
| Cam selection sbc | david ahluwalia | Engine | 13 | 02-03-2009 01:27 PM |
| SBC cam selection | bonuts | Engine | 3 | 06-09-2004 12:34 AM |
