Is this SBC cam solid or hydraulic? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2010, 10:53 PM
gas_guzzler's Avatar
Hi I got this cam with a jet boat 305 engine I brought (that was in parts and this cam was included as a spare). It's a flat tappet cam however I'm sure the seller told me it was a solid. But I'm thinking it is hydraulic because the spec sheet has 0.0 for the valve clearances on it? It's a custom ground cam made here in New Zealand so parts books probably won't help.
Please have a look at spec sheet and tell me what you think.
Old 03-09-2010, 11:01 PM
techinspector1's Avatar
Wiki Edits: 326
"0.000" hydraulic. Make sure what's stamped onto the rear of the cam matches with the paperwork. Found a cam in the Crane catalog with nearly identical specs...
operating range 1800-5600
Good low and mid range torque and hp, good idle, daily useage and off road, towing, performance and fuel efficiency. Light pleasure and ski boats, including jet boats. 2600 to 3000 cruise rpm's. 8.75 to 10.75 static compression ratio advised.
Old 03-09-2010, 11:04 PM
Thanks very much tech inspector
I will check that. I thought it must have meant it's hydraulic, but I'm selling it and I don't want to mislead any one.
Old 03-09-2010, 11:12 PM
Wiki Edits: 326
added info to post #2
Old 03-09-2010, 11:22 PM
Thanks, you're always very helpful
solid roller make more power than my flat tappet cam? jarrettandroski Engine 31 11-23-2009 11:55 AM
Do oem 350 sbc roller cam's take the same cam bolts as older ones? eric32 Engine 5 04-20-2009 04:12 PM
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 05:12 PM
SBC roller cam selection 307malibu Engine 5 12-15-2007 09:53 AM
what are the power gains from a solid lifter cam on small c.i. sbc 74chevyflat Engine 4 06-08-2006 06:49 PM
