SBC cam thrust plate question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2009, 12:30 PM
hi, we are building an 87 or newer SBC roller block engine. we bought the factory roller lifters, spyder, dogbones and cam thrust plate. everything fits but the thrust plate (this is the the piece that bolts to the front of the block around the cam). the 2 bolt holes in the plate are not spaced wide enough apart to match the bolt holes in the block and the hole in the center that the cam comes through appears to be to big. are there 2 different thrust plates on the newer SBC blocks??? i figure some of you machine shop guys should know... thanks
Old 02-26-2009, 04:40 PM
BOBCRMAN@aol.com's Avatar
Yes there were two different plates. It seems like I always have the wrong one in stock.
Old 02-28-2009, 09:41 AM
I also ran into this same issue. I just cut the bolt ears off the retaining plate, made it round and then used a cam button. Works great, no issues.
Old 02-28-2009, 04:07 PM
I think I have the one you need, and you have the one I need. 1st design camshaft retainer GMP part # 10088128 (one I have) is for bolt centers of 3.62". The one I need GMP part # 10168501 is for 3.294" bolt centers. They are about $13 on their web site. Summit has em too for about $18. Enter 10088128 in search box.
ssmonty
Cam question 78 monte Engine 4 07-12-2006 08:26 AM
56 SBC cam lift question kohle1ce Engine 2 04-25-2006 12:46 AM
Cam Question? Sbc joe brienza Engine 0 04-22-2006 06:19 PM
SBC Cam interchange 19_Chevelle_69 Engine 4 10-30-2004 06:36 AM
question on cam & oil pump install chev 350 solowookie Engine 16 04-03-2002 04:25 PM
