SBC cam thrust washer?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2008, 02:38 PM
Hey guys another quick question here. Just wondering on a stock small block chevy what stops the cam from lateral movement?? on my SBC i tore down, the camshaft didnt have a thrust washer or anything to prevent it from sliding forward and backward, once I took the chain off the gear i could just slide the cam right out the front. Does this mean that on a SBC the chain is the only thing holding the cam in place and preventing it from sliding forward and backwards??
Thanks for your help,
Keith.
Old 02-01-2008, 02:48 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
You are correct sir, the chain is the only thing keeping the cam in place, except for the lifters...and the distributor gear.
On a roller cam a cam button is used because roller lifters don't hold the cam, also a button is used on a gear drive and recommended camshaft endplay is usually .007" to .015" but varies with manufacturer.
Old 02-01-2008, 04:48 PM
justold's Avatar
On a flat tappet cam the lobes are ground at an angle so the tappets will rotate and this in turn pulls the cam into the block along with the distributor gear .
Old 02-01-2008, 05:29 PM
Ok thanks for the info it makes sense to me now
SBC roller cam selection 307malibu Engine 5 12-15-2007 10:53 AM
Timing woes on SBC 350 with bigger cam. Brawler Engine 5 09-07-2007 05:33 PM
Cam Bearings and Core Plugs (SBC 350)89 gandl2123 Engine 15 03-26-2007 04:06 AM
SBC Cam Sprockets Question Will H Engine 42 01-01-2007 12:16 PM
Roller Cam Help Please Sbc 1985fiero Engine 3 06-21-2006 11:57 PM
