-   -   sbc camshaft identification (http://www.hotrodders.com/forum/sbc-camshaft-identification-169588.html)
377tk 12-06-2009 09:49 PM
I have a camshaft that cam in my 377 and it has # 965634 stamped on the end of it no other identification can be found other than casting#s between lobes behind the gear of 1579. I check with competition cams, summit clay smith ect. and the numbers are not matching anything the ground and info on this cam would be appreciated.
fast68 12-06-2009 10:21 PM
ill tell you the same thing i was told when i asked long ago about a cam i have laying around
measure the lobes
and it is what anyone else is told to do because most of the time numbers are useless on cams
