SBC casting#3970010 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2009, 07:03 PM
SBC casting#3970010
I just found a very badly rusted out 1968 Chevelle nothing left of car but it has a what i think is a 350 in it casting number 3970010, is this maybe the original engine and is it a good one to pull and rebuild. Does anyone know what HP it might be if its stock.
James
Old 06-22-2009, 07:16 PM
XNTRCI-T's Avatar
AKA Lee in KC
3970010s are as common as dirt. Look at the passenger side of the block at the front of the cylinder head. There should be a machined pad there with stamped alpha-numerics. There should be a letter followed by four numbers followed by two or three letters. Post that alpha-numeric here and we will look it up for you. Or you could go to chevymania.com or nastyz28.com and look it up yourself.
Old 06-22-2009, 07:29 PM
cool rockin daddy's Avatar
Or Mortec.
Old 06-27-2009, 09:51 PM
dot 5 blinker fluid
sbc
James
68 is a 327 69-79? is a 350 under that # i would consider getting it if its a good $
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Lunati cam and 305 sbc questions in a Frankenstein low budget rodder Engine 13 06-30-2009 04:55 AM
What to consider when choosing your first SBC build? CandiMan Engine 16 05-25-2009 07:50 PM
eaton m112 blower sbc manifold? oklowride Engine 3 12-25-2006 01:21 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
