Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC Casting number 3932388
Old 04-28-2013, 06:44 PM
gearheadslife gearheadslife is offline
Banned
then find a 2 bolt 350 block..
add splayed 4 bolt caps, and a 383 set up..
and good heads..
with a little marvals mystery oil and a prime of the oil system, you can get that buddies 350 running.. without opening it up.. spray the mm oil in the spark plug holes and walk away, in a few hours try to slowly by hand turn the engine back and forth... once loose.. spray more in the holes and turn it over a few times.. then prime the oil system.. then fire in the hole..
run that and then start building the 383
