SBC Casting number 3932388 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2013, 04:50 PM
Slammedsi's Avatar
I had been on the lookout for a sbc to set on a stand a do a rebuild on and place in my 77 C10. I located a sbc with a block casting number of 3932388. The guy that has it is a good friend. He said he pulled it out of the running car back in the late 80's. Its been on a engine stand sense. Its a complete motor from carb to pan, and never been apart. From my research is a 350 Cubic Inch 300hp motor, from 1969. My friend could not remember what it came out of (old hotrodder that's pushing close to his 80's) but stated it was running when pulled. After setting up so long im sure it needs to be gone through. My question is one, is it worth the 400 bucks he wants for it, and two is this a good motor to shoot for my goal of 400 whp. Thanks for the help.
Old 04-26-2013, 09:39 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Sounds like a good price for a carb to pan motor. Did you run the numbers off the front pad to get your HP numbers?
Semper Fi
The Following User Says Thank You to 68NovaSS For This Useful Post:
Slammedsi (04-26-2013)
Old 04-26-2013, 10:06 PM
Slammedsi's Avatar
After researching the casting number I came across a book I had that stated it was a 300hp motor from the 1969 cars i.e. nova,camero, chevelles. Also found a post on another website asking about the same casting number.
Old 04-27-2013, 09:39 AM
vinniekq2's Avatar
If you still want 400 rwhp and it is going into a (heavy) truck,what you should consider is a bigger engine with more torque.You might need as much as 550 HP to get 400 to the rear wheels. To get 550 hp from a 355 expect to rev the engine to 7,000 rpm (ish) or you need a power adder. Any engine that makes 1.5 hp per cubic inch is a serious engine with all the right parts.
Buying a cheap core is a very small part of the project,,,you will be miles ahead just buying a new block with the appropriate size to start with. A mild 454 is a better place to start if you have little experience with engines.If you rally know your engines then build the engine that best suits your style of driving.
The Following User Says Thank You to vinniekq2 For This Useful Post:
Slammedsi (04-28-2013)
Old 04-28-2013, 07:32 AM
Slammedsi's Avatar
I'm still on the fence. This was never planed to be a fast build. So cost is a factor. I'm not opposed to having the 350 stroked to a 383ci
Old 04-28-2013, 10:48 AM
vinniekq2's Avatar
Heres an idea; source a machine shop that sells exchange engines.Ask them to piece a vortec engine together but use a 3.62 stroke crank(stock GM 6 liter) a 4.03 bore. Buy a set of modified vortec heads from a reputable dealer like scoggin dickey. Use a 450-480 lift roller hydraulic cam around 224 ish duration and what ever bolt ons you like.
Drive the truck,,,,,
the engine will make 400 hp plus or minus,will rev freely to 5500 plus RPM,have a nice power delivery and very responsive.
To make more power,expect to spend a lot more money. Quit looking for some super deal in a forgotten barn,just get what works and doesnt cost much. If you dont abuse the engine,I see no reason to buy forged pistons or floating pins etc. DO: balance the engine!
Old 04-28-2013, 11:13 AM
vinniekq2's Avatar
also (forgot to mention) when you are at the rebuilders,look through the buckets of roller followers until you find a decent set.They should be next to free?
Old 04-28-2013, 12:46 PM
Slammedsi's Avatar
I guess I haven't mentioned that I'm not opposed to spraying my way to 400whp.
Old 04-28-2013, 04:11 PM
vinniekq2's Avatar
How many times do you think you can spray a budget engine with hyper/cast pistons?
If you want a 500 plus HP engine:YOU GOTTA PAY THE PARTS GUY!
Old 04-28-2013, 05:01 PM
Banned
So easy to spend other peoples money..lol
the o/p said budget,, it is a truck it's a c-10 so 2wd mostlikely 4000 lb's ish just like my 71 (mine is a long box, short will be less)
o/p said he wants 400hp at the wheels, let me burst your bubble,
you will have a hard time getting that power to the ground with the factory leaf spring set up as is.. plan on spending bucks here..
400 bones isn't bad for a known running 350 you can get it running now without pulling it apart.. it's not that hard..
it being a 300hp 350 means zero if you are going to rebuild it..
other than check to see if it's standard bore, a 4 bolt block and forged crank..
if it's not as above ,any 150 dollar 350 core will do.. as you'll only be use'n the crank/rods/sheetmetal/head castings(maybe) and the block..
if it's got a forged crank it's worth every pennie of the 400 bones..
rethink this, shooting for the stars is nice.. but an honest 300hp to the wheels will make your truck FLY.. if it hooks..
these trucks are not all that heavy compaired to later trucks..
if use'n a 3spd auto ,use'n a th350 will get a few more to the wheels than the th400..
if going 383, the worth of your bud's 350 is really zero..
as I'd want to start with a standard bore 2 bolt block and add splayed main caps..
The Following User Says Thank You to gearheadslife For This Useful Post:
Old 04-28-2013, 05:50 PM
Slammedsi's Avatar
Ive personally seen a bone stock sbc (400) sprayed into the mid 8's with nothing more then a quality exhaust and a cam ground for the use of n20. It was in a gutted 84 C10 with a TH400 and a 3500 stall. Sprays anywhere between 100 and 150 through a carb plate. Granted it did run a good sized pair of slicks. Its been run every Thursday sense 2005 at kenedale raceway here in Texas. Guy "Claims" over 400 passes with out a single brake down or overhaul.
these trucks are not all that heavy compared to later trucks..
I really like burn outs! lol. To be honest my main priority is to get the hp to where i want it, Then start on the rest of the components as time and money allow. I know im doing it backwards haha.
Old 04-28-2013, 06:44 PM
Banned
then find a 2 bolt 350 block..
add splayed 4 bolt caps, and a 383 set up..
and good heads..
with a little marvals mystery oil and a prime of the oil system, you can get that buddies 350 running.. without opening it up.. spray the mm oil in the spark plug holes and walk away, in a few hours try to slowly by hand turn the engine back and forth... once loose.. spray more in the holes and turn it over a few times.. then prime the oil system.. then fire in the hole..
run that and then start building the 383
sbc casting number atcoed Hotrodding Basics 3 02-25-2011 12:13 AM
SBC Head casting number 3873487 50BLUECHEVY Engine 2 12-24-2008 07:17 AM
SBC Casting Number... Mike_82 Engine 3 03-11-2004 04:05 PM
SBC casting number Maverick Engine 1 12-10-2002 07:38 AM
010 SBC casting number question's stereodud Engine 4 10-21-2002 07:27 PM
