Sbc Chevy ticking - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2012, 08:31 PM
Sbc Chevy ticking
I am hearing a tap or clicking noise in my fresh 383 with about 1000 miles on it. I recently added mufflers on it after running open lake pipes, so I can finally hear stuff. The noise sounds like its coming from the harmonic balancer only when it get hot. I removed the belt thinking it was the water pump or pulleys and no luck. I also have good oil pressure about 30 psi at Idle. Could it be a thrust bearing, slight rod knock, and any input on checking. I had a rod knock on a different motor and it doesn't sound like that.
Old 04-22-2012, 09:13 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I've seen pulley bolts too long hitting the timing cover, but that would be a full time noise, until it wore down the spot it's touching.
Semper Fi
Old 04-22-2012, 09:22 PM
30psi sounds a little high at idle?
Are you running a mechanical fuel pump?
Old 04-22-2012, 09:51 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Your oil pressure is fine, especially for a new build.
Semper Fi
Old 04-23-2012, 04:08 AM
Iam running a electric fuel pump and pretty sure the fuel pump rod was removed, but I'll check again. Also oil looked cleaned after the oil change and still looks as clean as can be. The thing that scares me is it only does it while hot, which rules out accessory stuff.
Old 04-23-2012, 11:07 AM
Old 04-23-2012, 05:21 PM
T-bucket23's Avatar
Wiki Edits: 26
Check the timing tab. I had one hitting on the damper and it was very aggravating and not easy to find.
Chet
Old 04-23-2012, 06:50 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
What timing chain did you install ? could be the chain hitting JMO.
Cole
Old 04-23-2012, 06:55 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Opps, posted before I saw the other reply
Old 04-26-2012, 05:42 PM
Well, thanks for all the input, think I solved it. I pulled the crank pulley off and the ticking stopped. Looked like the holes were teemed out, so I bought a better one and again it seemed to solve it. It also got rid of a small vibration. Thx dides
sbc ticking~ looking for ideas Kinzik Engine 6 05-21-2011 10:32 PM
SBC 350 Ticking 1972scoutII Engine 7 12-19-2010 10:52 PM
more on ticking sbc -- oil pressure mhamilton Engine 3 12-26-2006 08:24 AM
still can't solve ticking sbc mhamilton Engine 47 12-11-2006 08:32 PM
ticking sound sbc Chevy Hi-Po Engine 13 12-28-2005 01:02 PM
