SBC Chrome pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2008, 04:02 PM
SBC Chrome pan
I'm finishing my new SB 350. I am installing a chrome steel oil pan and using the Fel Pro rubber gasket. I have had several people tell me to sand the chrome on the gasket surface area of the pan to ensure there will be no oil leaks. Also to not use any sealant anywhere. Is the true or false
Old 10-20-2008, 05:48 PM
Wiki Edits: 31
take the chrome oil pan, set it on the floor, and jump up and down on it... chrome oil pans rust out from the inside... but if you must.. sand the chrome off the mating surface to make it seal.. you could use a little sealant
Old 10-20-2008, 06:27 PM
T-bucket23's Avatar
Wiki Edits: 26
If it is one of those $39 pans it probably wont seal no matter wht you do.
Chet
Old 10-20-2008, 06:32 PM
techinspector1's Avatar
Wiki Edits: 326
Chet
I concur. Tried one once.......once.
Use Permatex High-Tack #97 to glue the gasket to the pan so it won't extrude out when you tighten the bolts.
Old 10-20-2008, 08:50 PM
MI2600's Avatar
Member# 3287
I agree with Matt...most of those pans have cheap chrome and the fits are terrible, besides showing all the crud you'll pick up.
I wish someone would come with a engine paint color called "Dirt".
Old 10-20-2008, 09:11 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
I have never been able to get a chrome oil pan to seal up. This is the same with valve covers, and timing covers.
I have taken the chrome off of the gasket surfaces, and in some cases just used silicone (Permatex Ultra-Black) with no gasket, but they still leaked.
Mostly what I found wrong was the extremely thin sheet metal flexed too much. Even factory pans, etc. will start to flex over time.
If it is unused try to sell it, and invest in a quality oil pan. Expect to pay over $100.'s for it, and make sure you order the recommended oil pump pick-up screen.
SBC oil pan removal? v8hed Engine 11 07-08-2008 11:02 PM
Wich oil pan you use on your 383 stroker? TVR383 Engine 10 01-30-2007 08:21 PM
SBC oil pan question WakBordr7387 Engine 2 06-25-2006 07:13 PM
Sbc 400 Oil Pan weedhopper Engine 7 06-18-2006 09:23 PM
can the wrong oil pan make this sbc leak? bigwildgrin Engine 10 12-19-2005 07:33 PM
