Are you doing the test with the carb at WOT, all plugs out?
You can do a search here for valve adjustment procedures, hydraulic or solid. |
nova,
I was doing the test with all plugs in minus one with comp gauge, just rolling it over with start button as far as the compression test goes. is that what you meant? as far as valve adjustment, I have pretty good idea on how it works. I just don't understand why some rockers (in my case 2 of them) splurge more oil than the rest. nothing has been adjusted with it running yet. this is all preliminary with just cranking it over. |
If I understand you correctly, you have not fired the motor since you got it back together and are performing the test on a cold motor. I don't see how you're going to learn anything from doing a compression test at this point. The rings are not seated and won't be for several hundred miles. The only thing I see that you're doing is wasting time and wiping all the assembly lube off the cam lobes. The lobes and lifter crowns are lubed by oil splash off the crankshaft and what little oil runs down off the bottom of the cylinder bores. If the crankshaft isn't spinning fast enough to sling oil (like during a compression test), then the cam lobes and lifters are running dry. Bad juju bwana. |
Well noted on seating the rings then doing compression test.
But in all fairness, I might be new at this but doing a cold compression test when I got this told me this had bad rings and in my case a broken piston land, so that wasn't a waste of time. also wouldn't doing a compression test regardless of miles be insufficiently getting oil to the cam and lobe base? The cam I am using was previously used, if it were brand new I wouldn't have tried a compression test before break in and I only turn the engine over twice while putting in a cam and adjusting lifters, trying to get practice getting that right, so I can break in a cam. I am just not sure if oil gushes out of a rocker if it means too tight or too loose, all the rockers get oil, just two are getting alot more than others. thanks guys |
| 350 valve adjustment | camaro lover | Hotrodding Basics | 3 | 03-18-2011 08:06 PM |
| 350 valve adjustment | turbofirebird350 | Engine | 6 | 03-18-2011 03:34 AM |
| valve adjustment on 69 FE 390 | 62fordpickup | Engine | 0 | 06-03-2010 12:10 PM |
| big block chevy valve adjustment trouble,no compression | dufrain | Engine | 11 | 09-28-2003 08:07 AM |
| Valve adjustment | T-Bucket | Engine | 5 | 05-22-2002 09:04 PM |
