Originally Posted by sunsetdart
Here's something to remember for all car guys who watch the temp gauge more than they watch the road:
Most all temperature sensors for the gauge are located near the thermostat housing. So what are you actually seeing on the gauge?
Well as the coolant circulates throughtout the motor, it picks up heat from internal metal surfaces. So it keeps moving picking up heat and as it passes the sensor it will register the temperatur of the coolant.
BUT.....here's where everyone gets crazy with seeing the gauge..........the coolant is at it's hottest is leaving the motor. You are not gauging the temp of what's in the motor.You want a motor to run in the 190-210 range for making max HP. You run a motor too cool and you are not burning the fuel totally and you can have excess gas wash down the cylinders.
If the fan,pump, and radiator have done their job, the coolant coming back into the motor on the bottom hose should be 15-20 degrees cooler............but again, you are not gauging those temps.
Stop watching the gauge and enjoy the drive..........and firebird is correct..........electric pumps are for race cars, not the street.
I understand this, but since the pump was on there when I took ownership, and it's working fine for the street I thought I'd leave it there. My questions were more about the fans than the pump.
With my current setup, the fans are supposed to turn off at 180* but since the stat is a 180*, and we all know that stats and fan controllers have some tolerances, once the fans turn on the temp never gets cool enough for them to sut off. Even on the hiway the fans run. Since I've never had any great experiences with adjustable fan controllers, I thought if i dropped to a 160* stat and a controller that shut off at 170* my fans would not be running on the hiway.
As far as effeciency at temps, I made my first dyno pull at 180*. At the end of that pull the temp was at 230*, so, I idled the truck with some huge blowers running good aie thru the rad and got the temp down to 200*. I made the second pull and lost about 35 hp and 44 lb/ft, I'm assuming from the higher temp. Now, as I said before, I think this is because of the stready coolant flow from the elecrtric pump, and was wondering if a higher flow stat would help the temp spikes on a hard pull.
