Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 06-15-2002, 08:54 AM
HotRodF100's Avatar
HotRodF100 HotRodF100 is offline
Post SBC Cooling bypass line question
My 350 SBC does not have a bypass hose, instead it goes to the heater core. I have seen 2 scenarios on a SBC, a bypass line and no bybass line. My questin is, if I don't have a bypass line can I shut off the water to the heater? The heater core in my F100 is new and has been problem free, at least until I shut off one side of the water flow. I installed a vacuum operated valve off of a Buick to shut off the heat in the summer. Soon after this, my core developed a leak. The shutoff valve never completely shut off the water to the core, this was evident by a little heat. Is it possible that without a bypass line the heater is the bypass and the high pressure caused a leak, or is it just a coincidence that the leak started? For now I'm going to disconnect the heater core and install a bypass on the motor. This will give me time to fix my leak but sooner or later I'll have to put it back in.
Old 06-15-2002, 01:53 PM
mad van mad van is offline
Cool re: SBC Cooling bypass line question
hi, i dont know if this info will help but i run two temp gauges one in the manifold ,one inthe right head . i realised that when heater is on and heater valve is open that head tenp and manifold temp equalize .so i plan to route a bypass when heater is off.i found it only because of the two gauges there was as much as 10,20 degree c differance without bypass or heater.
Old 06-15-2002, 06:50 PM
Tom Tom is offline
Post re: SBC Cooling bypass line question
loop it...remove one heater hose completely and hook the heater end of the other hose to the block connection
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
