SBC cooling question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2005, 09:58 AM
stea's Avatar
If Im not running a heater do I need to run a bypass hose between the water pump and the manifold?
Old 05-27-2005, 10:06 AM
camaroman7d's Avatar
What small block do you have? SBC's do not have a bypass hose (big blocks do). Small blocks have the bypass built into the waterpump/block. I know this to be true for all small blocks from the mid-late 60's on up.
Royce
Old 05-27-2005, 10:18 AM
DoubleVision's Avatar
You can block them off without worry. We did so on the drag car years ago and left it that way when we street drove it.
Old 05-27-2005, 10:32 AM
stea's Avatar
New GMPP 290 H Crate Motor. getting ready to fire it up for the first time. I currently have the fittings in the water pump and the manifold blocked up. Just wasnt sure if I should connect the two since Im not running a heater core.
turbo sbc question. Super Chevy Engine 3 06-08-2004 05:57 PM
305 SBC question Aces0vr8s Engine 19 05-28-2004 09:18 PM
SBC Valve Cover Question Jag Daddy Engine 4 10-31-2003 06:03 PM
SBC rod question Jmark Engine 6 09-20-2003 11:29 PM
another wierd question on sbc heads stfinney Engine 3 11-24-2002 08:38 AM
