-   -   sbc crank casting numbers (http://www.hotrodders.com/forum/sbc-crank-casting-numbers-162704.html)
chevyman420 08-02-2009 06:05 PM
I have been searching the internet for a couple hours and can't seem to find this number anywhere 3832442. I have read that it could be that it should read 3932442 but don't know. Can someone please help me with this one?
BOBCRMAN@aol.com 08-02-2009 06:15 PM
When it comes to GM castings 3 6 8 9 0 can all look alike
Machine shops and crank grinders use the last three or four numbers. 442 is one of the most common cast cranks for 350 2-pc. seal engines
chevyman420 08-02-2009 07:34 PM
O ok that makes some sense. So then it could say 3932442 right. I'll go look again but pretty positive that it says 3832442.
jimfulco 08-03-2009 01:05 AM
That casting was also used in 267s and 305s, though the machining is different.
chevyman420 08-03-2009 02:15 PM
Ya it says 3932442 it just casting slag that makes it look like an 8.
