sbc crank casting numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2009, 06:05 PM
I have been searching the internet for a couple hours and can't seem to find this number anywhere 3832442. I have read that it could be that it should read 3932442 but don't know. Can someone please help me with this one?
Old 08-02-2009, 06:15 PM
BOBCRMAN@aol.com's Avatar
When it comes to GM castings 3 6 8 9 0 can all look alike
Machine shops and crank grinders use the last three or four numbers. 442 is one of the most common cast cranks for 350 2-pc. seal engines
Old 08-02-2009, 07:34 PM
O ok that makes some sense. So then it could say 3932442 right. I'll go look again but pretty positive that it says 3832442.
Old 08-03-2009, 01:05 AM
That casting was also used in 267s and 305s, though the machining is different.
Old 08-03-2009, 02:15 PM
Ya it says 3932442 it just casting slag that makes it look like an 8.
casting numbers onefastgtp Engine 8 04-08-2009 10:06 PM
87 Monte SS Rear differential Casting Numbers SmontecarloSS87 Transmission - Rearend 1 06-13-2008 07:07 PM
Hello and casting numbers sandiico Introduce Yourself 1 10-13-2006 01:09 PM
Ford Axle Identification ( Casting Numbers ) Ozsuba Transmission - Rearend 1 01-01-2006 10:55 PM
casting numbers ??? jackyandjoe Engine 5 07-01-2003 05:11 AM
