sbc crank question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2004, 04:25 PM
sbc crank question
will a stock cast iron crank withstand 400-450 hp? if so what about rpms (im going to be turning at the most 6,500-6,800) and if it matters im talking about a 350 crank and im using eagle sir rods, and it is a 4-bolt main block with ARP main bolts
Old 02-14-2004, 04:44 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
You will prroooooobably be ok. Its not your HP that is going to do it, its the R's. BTW, you can make that hp at much lower RPM, why not do that?
Read this link for more info:
duability secrets
K
Oh yeah, btw, get it ballanced and you're in much better shape.
Old 02-14-2004, 04:51 PM
because im runing a high axle ratio (4.10)
Old 02-14-2004, 06:06 PM
lluciano77's Avatar
A higher gear ratio should make it easier on the crank. There will be less load. It won't be able to spin more RPMs though, and with higher numerical gears your RPMs will come up a lot quicker.
Old 02-14-2004, 08:48 PM
well thanks for the reply guys, some very good thoughts, what price range could i get a good forged crank for and is there any downsides to a forged crank?
Old 02-14-2004, 09:12 PM
The only downside to forgings is price. I have an Eagle 4340 forged 383 crank in my truck. I got it off E Bay N.I.B. for $400 some. They are up over $600 now @ Summit. Shop around, and whatever you do invest in having the entire assy balanced once you have everything. Pistons, rods, Crank, balancer, and flywheel/flexplate.
Old 02-15-2004, 08:10 AM
GTO 1965's Avatar
If you use the cast crank have the machine shop magnaflux it before they ever do anything to it, this will let you know if it has any cracks.
I've used cast cranks for years and turned them 6500 to 7000 with no problems!
