I want to check my valve adjustments on my 383 without removing the crank. In fact I probably can't get it off the motor as it sits in my boat and there's not enough clearance in front for a puller. Plus I just want to leave the belt package in place.
I do not want to turn my rotating assembly with the crank bolt.
What it the right name for that adapter rotator thing that you bolt on the crank pulley?
I'm searching around the usual web sites right now.
