SBC crank threads stripped. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2009, 10:38 PM
junior stocker's Avatar
Just finished putting a completely rebuilt .030 over 350 SBC engine in the 51 Business coupe. Found out two of the crankshaft flange bolt holes are stripped while installing the flex plate. How has anyone repaired this? Is there another "manufacturer" that uses a slightly larger diameter thread bolt we could drill and tap to? Or, would a helicoil be strong enough? This sure ticked me off after all the work that went into this. Give me your best fix, I'd appreciate it. Thanks.
Old 07-18-2009, 11:03 PM
ericnova72's Avatar
More for Less Racer
HeliCoil would be the way I would do it, or go up one size to 1/2"-20.
Old 07-19-2009, 08:27 AM
heli-coil will work just fine.
sam-missle
400 Sbc With 350 Crank Six Inch Rods blown volvo Engine 53 02-17-2006 10:36 AM
stripped crank chevyelc81 Engine 5 06-10-2004 02:34 PM
stripped starter bolt threads 72chevelleguy Engine 2 12-11-2003 08:02 PM
SBC crank case pressure relief 383vette Engine 6 10-26-2003 08:39 AM
stripped crank snout gkev Engine 6 04-03-2003 03:34 PM
