SBC Crankshaft / Damper Sizes ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2010, 10:29 PM
Hi guys,we were having trouble with a 1979 SBC damper seal (timing cover)
We took measurements and came with this ones :
44.78 x 61,37 x 9.52 mm
What are the original sizes ?
Any info on the crankshaft area (where the damper goes) size ?
Somebody did some machine work on the damper we believe and the
seal is going on too tight bending the rubber lip and causing a leak
Thanks !
Old 09-06-2010, 12:28 AM
E.T. divided by $ spent= Speed
I beleive the make a collar for dampers that are worn and grooved to seal on the timing seal better.
Other wise get a new damper.For budget motor go to the yard and look for one were the rubber between the base and ring is not squeezing out the side or dry rotted,then pull it and make sure it isn't grooved at the seal line.
Old 09-06-2010, 06:42 AM
SSedan64's Avatar
Unless they welded the surface to build it up then didn't machine it small enough it can't be too large.
This is a Speedi Sleeve to repair the surface of the Balancer when the seal has worn a groove.>> http://www.rockauto.com/catalog/moreinfo.php?pk=257550 it has the Min. & Max specs.
Did you lube the seal with oil before intalling it?
Old 09-06-2010, 07:54 AM
Yes,thats what they did,they did sleeve it !
so thats why im looking at the crankshaft "pin" dimensions
to match the damper to specs
Thanks !
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Lunati cam and 305 sbc questions in a Frankenstein low budget rodder Engine 13 06-30-2009 04:55 AM
Summit Harmonic Damper SBC cowbay Engine 3 06-01-2008 02:39 PM
350 damper and snout questions Vortech 4.3 Engine 3 03-05-2006 08:03 AM
SBC mount bolt sizes Maverick Engine 5 11-02-2002 03:16 PM
