Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC cylinder head bolts .. cast iron heads Vs Alum. heads
Old 08-04-2006, 10:54 AM
cabowabo's Avatar
cabowabo cabowabo is offline
big Q
i use studs
i dont use bolts i use studs on all my engines but i wouldnt use cast iron bolts on alum heads thats why the alum head bolts are longer due to the alum head going to expand when hot so use the bolts for the alum head if you using the alum heads
