SBC cylinder head bolts .. cast iron heads Vs Alum. heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2006, 10:43 AM
hi
is it OK to use cylinder heads bolts from a cast iron headed SBC on Aluminum heads ??
I am asking because on some Aluminum headed SBCs I've seen bolts with washers and they are a bit longer
bolts for Iron heads
bolts for Aluminum heads
Old 08-04-2006, 10:53 AM
With aluminum heads you want to use the type with a washer, and lube the head up good with moly lube.
Old 08-04-2006, 10:54 AM
cabowabo's Avatar
big Q
i use studs
i dont use bolts i use studs on all my engines but i wouldnt use cast iron bolts on alum heads thats why the alum head bolts are longer due to the alum head going to expand when hot so use the bolts for the alum head if you using the alum heads
Old 08-04-2006, 08:34 PM
They need to be longer to account for the thickness of the washers. If you don't use washers, the bolt heads will dig into the head. If you use washers and stock bolts, there won't be enough thread engagement.
Cam Help black66 Engine 3 05-12-2003 06:15 PM
iron performance heads for SBC LD85 Engine 39 05-03-2003 06:44 PM
1BAD80 or anyone BERN Engine 3 04-17-2003 07:11 AM
SBC head bolts fred56 Engine 2 03-27-2003 10:44 AM
sbc heads Jared Engine 7 03-03-2003 07:07 PM
