sbc cylinder head question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2007, 05:29 PM
im rebuilding a 350 just trying to build a good street motor. Nothing crazy.
I have 2 sets of heads! Both need rebuilt but wondered which pair I should start with?
first set. 462624 76cc this head came on the motor but i read somewhere that these were lighter weight castings and where prone to cracking?
second set 3795896 these are 60cc heads from 62-64 327's
I am just starting this teardown/build. I havent purchased any pistons yet.
thanks for any answers/comments in advance.
dustin
Old 06-05-2007, 08:58 PM
DoubleVision's Avatar
For the cash you`ll sink into those heads you can get a aftermarket set that is far superior. The 624 castings are junk, light and crack prone. The 896 castings are small valve, small runner heads without accessory holes that will choke the engine to death.
Old 06-05-2007, 10:11 PM
F-BIRD'88's Avatar
Yada Yada Yada
I agree neither set are worth using for a performance motor. Unless you want a "low performance" motor. Buy some real High Performance heads. There are many to choose from.
SBC 18 degree head compared to 23 degree head powerwise? sb72elcamino350 Engine 7 03-09-2010 02:01 PM
sbc cylinder head chevystroker Engine 7 07-30-2004 12:40 PM
SBC Head Question? Jag Daddy Engine 8 05-14-2004 06:50 AM
sbc head question stfinney Engine 3 09-03-2003 05:13 PM
head gasket question RiceMuncherdude Engine 2 03-12-2003 03:01 AM
